#141 |
Do the new sv's still have this issue?
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#142 |
if your on about the gladioli then no, if your on about the L2 SV then yes as its still the same set up.
#143 |
update.
i have emailed various laser cutters and i'm waiting on quotes coming in. and again i apologise for the delay. Lance |
#144 |
There is no delay. take your time mate.
#145 |
#146 |
As long as you're not charging by the hour lol!
#147 |
I knew a plumber like that once, drove to macc to get more parts and charged me for the time he was "off site"
#148 |
Bumped to keep it near the top.........
#149 |
No worries there fella, take your time and good luck with finding the best place. Sending hugs your way
#150 |
Is it too late to get in on this action!?
potential pointy ecu restrictor kit bargain | haydensv650 | Stuff Wanted | 0 | 18-08-11 07:40 PM |
Replacement chain adjuster plates? | SV400Rob | SV Talk, Tuning & Tweaking | 13 | 02-02-11 09:30 PM |
chocolate chain adjuster plates | dmracing | SV Talk, Tuning & Tweaking | 6 | 01-08-09 09:23 PM |
Chain adjuster plates | dmracing | Stuff Wanted | 6 | 24-07-07 05:54 PM |
Stainless adjuster plates.....................bling | svrash | SV Talk, Tuning & Tweaking | 19 | 23-04-06 07:22 PM |
