Old 30-06-12, 06:18 PM   #371
Aidan
Default Re: Potential pointy Adjuster Plates Group Buy
Recieved and installed! I'd post a picture but I'd end up getting abuse for the state of my bike
Old 30-06-12, 06:26 PM   #372
any feedback is more than welcome good or bad.
Old 30-06-12, 07:29 PM   #373
peterco
peterco's Avatar
Originally Posted by sniff View Post
Shame that wheel isn't very!!
A wheel on the bike is not for show,the wheel will get dirty when it is in use
Took photo this morning
Chain washed/cleaned and lubed.....soon to have a scottoiler
Have got to say it a decent bit of kit.
Well done.....
SV650 Sport in Black
MZ saxon tour 301
Previous bikes
SV650 Naked
BMW 650cs Scarfer
MZ RT 125 4 stroke
peterco is offline   Reply With Quote
Old 01-07-12, 03:38 PM   #374
Jayneflakes
Jayneflakes's Avatar
Come and listen to the radio station today, might have a bit of feedback for you on there this afternoon between now and seven PM.
www.bikerrockradio.com
Jayne you're a Pussy Magnet
Old 01-07-12, 06:13 PM   #375
muzikill
muzikill's Avatar
Now it makes the rear axle nut look untidy!
Old 01-07-12, 11:50 PM   #376
sorry Jayne but i was tooo busy enjoying myself on the Isle Of Bute
hope they were kind words. thanks for the shout if you did mention them.
did you polish them?
your just married so you shouldn't be messing with bikes. your a bad boy now go pleasure your wife
Old 02-07-12, 08:36 AM   #377
Aidan
Ok, a review - I will try to post a picture with the scottoiler later. Overall very pleased, scottoiler is far better located than it was with a bolt though the bobbin hole on the swingarm. Otherwise it is clearly better quality than the OE part which had previously spun round and gouged the swingarm. The fit to the bolt/spindle through the wheel is far better and the accuracy of wheel alignment would be better - however tbh I count the threads on the adjuster rods instead (as I think that is probably the most accurate way of aligning the wheel).
Overall, very happy!
Old 02-07-12, 10:10 AM   #378
Jayneflakes
hope they were kind words. thanks for the shout if you did mention them?
They were kind words indeed along with a thank you.
Old 02-07-12, 05:53 PM   #379
Jayneflakes
It has taken me a couple of days to fit these little jewels because of my shoulder injury being rather painful. But there was only so long I could hold off playing.
Time for some feedback to the lovely Bibio.
First of all, the difference is huge.
Fitting is easy.
Setting the chain oil feed pipe could not be easier.
The feed pipe in final place.
Once in place, it looks lovely.
I do not have any negative comments to make, I cannot think of any thing that could be improved and fitting is an absolute doddle. Thank you Lance for a great little bit of kit. You are a star.
Oh by the way, is this clean enough for you fussy lot?
Old 02-07-12, 06:08 PM   #380
thank you Jayne. those look absolutely lovely on the silver swingarm.
just a couple of comments. if you want to take the battle scar out your swingarm you can use a bit of scotch brite pad and rub along the grain, this will bring the grain affect back and mask the scar better. i would also advise that you try and get some slack in the pipework for your oiler as it looks a bit tight. if you move the nib a bit more away from the chain and a teensy weensy bit off the sprocket the oiler will work better as the oil then has centrifugal force to do its job better. otherwise top notch job
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
