Old 13-07-12, 02:21 PM   #451
Jayneflakes
Jayneflakes's Avatar
Default Re: Potential pointy Adjuster Plates Group Buy
Originally Posted by bladesuk1 View Post
when you do, please put me down for a set with the scottoiler attachment (although i'll be using a tutoro). and from reading through the rest of the thread, i think you deserve some lazy time
b
They work fabulously well with a Tutoro, I use one too, Pic in this thread somewhere.
I even sent a link to this thread to Tutoro so they could see what was being done.
Jayne you're a Pussy Magnet
Old 13-07-12, 02:23 PM   #452
Elliott
Receive today look fantastic, shame i binned the bike eh! :P
Old 13-07-12, 02:56 PM   #453
bladesuk1
Junior Member
funnily enough, that's how i found this thread in the first place!
am i right in thinking that you're using the scottoiler dispenser plate adapter, by the way? and that i won't need to use the tutoro helix with this, and that only the single-sided feed will be required?
b
bladesuk1 is offline   Reply With Quote
Old 13-07-12, 03:58 PM   #454
muzikill
muzikill's Avatar
Fitted today. Thanks Lance well chuffed & time to buy a tutoro now someone else has confirmed it works with it (pics?)
I wonder if suzuki uk has caught onto these yet?
Old 13-07-12, 04:03 PM   #455
Jayneflakes
b
Cool, was it on the Tutoro Forum?
In answer to your question, yes I am using a Scot Oiler dispenser plate which I now have held in place with a piece of heat shrink. The feed tube sits nicely in place with out the Tutoro wire. I only use the single feed because I have the auto and it provides plenty of lube to my chain. I did not feel the need to use my twin feed.
Old 13-07-12, 04:09 PM   #456
Jayneflakes
Pics of mine on page 38. I use a Tutoro Auto, mounted on my swing arm, just in front of my hugger.
Old 13-07-12, 04:26 PM   #457
what a clever idea. i would never have thought of that. so your not just a pretty face after all
Old 13-07-12, 06:14 PM   #458
Jayneflakes
I used the heat shrink to tie it on and used a double bow as the knot!
am clever me...
Old 14-07-12, 05:27 PM   #459
Toooldtodie
Toooldtodie's Avatar
What news on a new batch? Will be changing chain and sprockets in the next few months and would like to replace OE adjuster plates with a properly engineered set not made out of Cruddite. They work and look the nuts too, excellent!!
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 14-07-12, 05:39 PM   #460
batch will be ready end of next week or sooner.
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
