Old 20-07-12, 12:56 PM   #461
Default Re: Potential pointy Adjuster Plates Group Buy
new batch ready.
Old 20-07-12, 07:47 PM   #462
The Guru
I only got around to fitting them tonight.
Absolutely spot on
Ace job Lance. I look forward to what ever other replacement parts you engineer.
Old 20-07-12, 10:27 PM   #463
appollo1
appollo1's Avatar
any plans for curvey ones in the pipeline Bibio?
i'm not old i'm experienced!!
http://www.german-shepherd-rescue-scotland.org.uk/ everyone deserves a second chance
RIP Appollo miss you and will always love you x x x x
appollo1 is offline   Reply With Quote
Old 20-07-12, 11:01 PM   #464
yes and your designated test pilot. lol
if someone were to lend me a curvy swingarm, wheel spindle and nut i could get it done a lot quicker.
Old 21-07-12, 12:14 AM   #465
appollo1
appollo1's Avatar
mine is always available if you need it
Old 21-07-12, 03:33 AM   #466
SoulKiss
SoulKiss's Avatar
Fitted my plates today
Looking good
Old 21-07-12, 11:07 PM   #467
so far it seems everyone is happy which makes me happy.
Old 23-07-12, 08:28 AM   #468
aliwakeskate
Bibio, you are a legend! Just got the scottoiler bracket this morning first thing. Awesome!!
Old 23-07-12, 12:12 PM   #469
use a bit of threadlock on the threads if you don't have threadlock then you can use a bit of superglue but you have to work quick with the superglue.
Old 03-08-12, 02:23 PM   #470
bladesuk1
Junior Member
Cool, was it on the Tutoro Forum?
yes, it was.
In answer to your question, yes I am using a Scot Oiler dispenser plate which I now have held in place with a piece of heat shrink. The feed tube sits nicely in place with out the Tutoro wire. I only use the single feed because I have the auto and it provides plenty of lube to my chain. I did not feel the need to use my twin feed.
heat shrink... now there's a good idea! saves the messiness of a cable-tie, and less likely to snag. i'll have to try that out myself!
i have to admit i'm still in two minds between the tutoro and the scottoiler - used to have a cagiva raptor 650ie a few years ago (it was written off while filtering at 5mph when a car driver decided to turn into me) and fitted a scottoiler to that. it was pretty easy to fit, the unit hid under the seat, and splicing into the vacuum feed was easy enough, and it worked just fine. i'm leaning more toward to tutoro at the moment, though, if only because it's something i've not played with before...
bladesuk1 is offline   Reply With Quote
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
