#471 |
do yourself a favour and get a scottoiler. scottoiler is often copied but never bettered they have had 26 years of development. you can pick them up second hand very cheaply and if there are parts missing scottoiler sell them.
#472 | ||
Oh jolly good, I was not sure if anyone read my thread.
#473 | |
Junior Member
actually, i've re-read it a couple of times now. it's pretty helpful in getting a handle on the tutoro auto. actually, one thing i was going to ask - did you end up leaving it mounted to your swingarm, and if you did does it work as expected? seems like a really neat place to hide if from view but still have access, so if it works i might do the same. i used to have my scottoiler under the seat, but i couldn't do a quick visual check on it there so i'd rather have it visible...
i've gone for the tutoro in the end, anyways. i figured if i don't get on with it, i'll sell it on and replace it with a scottoiler, but it was worth a go given the price differential. |
#474 | |
#475 | |
Junior Member
![]() ![]() thanks for your help! b |
#476 |
Finally going to get round to fitting mine at the weekend. My 24mm socket and torque wrench arrived today. Is there anything else I need? I have a paddock stand. Do I need a tub of some form of grease?
#477 |
yes grease would be good for the spindle. get a can of white spray grease as its more useful as you can use it for the pivot points e.g. brake/clutch leavers, footpeg, gear/change leavers etc.etc when your doing a service.
tip, use a 22mm spanner on the other end of the spindle when your undoing the nut as this helps stopping the OEM adjuster plate from spinning. |
#478 | |
White Spray Grease? http://www.halfords.com/webapp/wcs/s...egoryId_165705 |
#479 |
yup that will do. when your putting it on the spindle spray it and leave the spindle to the side till the grease dries a bit. try and keep it off the threads.
#480 |
Bib is there a reason the scottoiler bracket couldn't be mounted the other way around so that it is closer to the sprocket ?
potential pointy ecu restrictor kit bargain | haydensv650 | Stuff Wanted | 0 | 18-08-11 07:40 PM |
Replacement chain adjuster plates? | SV400Rob | SV Talk, Tuning & Tweaking | 13 | 02-02-11 09:30 PM |
chocolate chain adjuster plates | dmracing | SV Talk, Tuning & Tweaking | 6 | 01-08-09 09:23 PM |
Chain adjuster plates | dmracing | Stuff Wanted | 6 | 24-07-07 05:54 PM |
Stainless adjuster plates.....................bling | svrash | SV Talk, Tuning & Tweaking | 19 | 23-04-06 07:22 PM |
