Old 15-01-13, 03:54 PM   #1
650
650's Avatar
Default Useful GSXR Front and rear wheel conversion info
I presume this will of been linked on here in the past maybe, but I thought it'd be handy for people who're wanting some info on what's compatible. Only thing I can't seem to see is what the diameters for everything are on the SV haha! So if anyone could add that it'd be brilliant.
Front fork conversion
http://sv650.eviltwinsbk.com/gsxr-fo...p-information/
Rear wheel conversion
http://sv650.eviltwinsbk.com/gsxr-re...50/#comment-14
Rear shock swap info
http://sv650.eviltwinsbk.com/oem-sho...on/#comment-11
Generally loads of info:
I'm unsure as to how awesome all that is as I'm completely clueless, but I'll be giving it a good read tonight!
650 is offline   Reply With Quote
Old 15-01-13, 03:57 PM   #2
Default Re: Useful GSXR Front and rear wheel conversion info
that's just an expanded version of the one that's on svrider.
good tough.
Old 15-01-13, 03:58 PM   #3
definitely worth a read
Old 15-01-13, 04:23 PM   #4
650
650's Avatar
As a complete and utter noob to all this, is it relevant to know what the diameters of the triple clamps are on the SV or are you simply replacing absolutely everything up front? I've seen a few 'complete' front ends from gsxr's on the bay, but they never seem to come with things like wheels and discs...so it's those bit's I'm always wondering about.
Old 15-01-13, 09:48 PM   #5
Nicky S
Nicky S's Avatar
i think im right in saying that nearly all front fork mods need the triple clamps changed except one where the forks slip straight in ????? (am i right)
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 15-01-13, 09:54 PM   #6
Runako
Those are the bits that are probably hardest to come by (including a top yolk). Probably best way to do it if you can't find a complete set with wheels/discs is to buy each component bit by bit starting with the least common. But I have no patience so I gave up.
Old 15-01-13, 10:37 PM   #7
dkid
Not seen this chart before. Looks like a good reference though, and might make the task of a gsxr front end swap a bit less daunting for those people who don't have vast experience/knowledge.
Thanks for sharing
Old 16-01-13, 06:24 PM   #8
bellisan
Right. But fairly unlikely, since most of the fork swaps are for USD forks, so the diameter of the clamp required in the triple is vastly different.
Old 16-01-13, 09:26 PM   #9
Nicky S
Nicky S's Avatar
im sure some none USD forks swap straight in, maybe from a SRAD
Old 17-01-13, 08:32 AM   #10
SRAD are massive compared to stock.
GSXR Rear Wheel Conversion (pointy) CheGuevara SV Talk, Tuning & Tweaking 19 05-06-16 03:11 PM
GSXR Rear Wheel Conversion Kit? Galviniser SV Talk, Tuning & Tweaking 11 06-10-12 08:40 PM
gsxr rear wheel conversion kit tetol Stuff Wanted 0 26-03-12 07:23 PM
GSXR rear wheel conversion measurements? ghigo SV Talk, Tuning & Tweaking 12 20-01-12 09:47 PM
gsxr rear wheel conversion mickeymac SV Talk, Tuning & Tweaking 6 26-11-08 07:01 PM
