Old 20-12-08, 10:00 PM   #11
Alpinestarhero
Default Re: --FITTING GUIDE HERE-- Oxford HotGrips K3> PDF format
Heated grips will keep the palms and the beginnings of your fingers warm. They may keep the tips of your fingers warm, your thuumbs may stay warm. The tops of your hands will get cold if exposd to the wind; consider matching the heated grips with some handlebar muffs for complete warmth.
If your arms / body gets cold, then your hands will get cold regardless of if you have heated grips, muffs, thickest glvoes in the world. They are part of the solution to keeping warm hands in winter, but dont forget to layer up and have a good meal #
happy winter riding
Old 27-12-08, 04:49 AM   #12
briderdt
Thank you SO much for posting this, especially the link-ups to the fuse box.
Any way to get a picture of the throttle grip post-install?
Old 08-01-09, 08:53 PM   #13
Baldyman
I also used the guide which worked a treat.
The only step I had difficulty with was soldering the live wire to the fuse spare connector. How did you manage to get a good soldered connection?
Old 08-01-09, 10:45 PM   #14
charlie13
i've a similar guide I knocked up for a pair of daytona grips fitted to my curvy. it's 2mb PDF so i'll not post it here but if anyone wants drop me a line
Old 11-10-09, 06:36 PM   #15
Bunks
+1
Sorry to revive an old thread.
Has anyone actually managed to solder the wire into the connector box? Am I missing something, can you get in it and take the metal connector out so you can solder it?
Also my one didn't have a lug to fit into the throttle, have they changed them? I expect once it's super glued on though it'll be fine.
Nick
Old 23-11-09, 09:43 PM   #16
TeddyBearKing
just read through this post, and i've got a set of daytona grips which i would like to fit. I was gonna use the guide for the oxford grips, but would very much like to see how you fitted the daytona ones
they will be fitted to a pointy, but i reckon with 2 guides i will be able to figure it out
Old 23-11-09, 11:03 PM   #17
StuL
I must thank you for making/posting this. I used this guide a few weeks ago to fit my oxford grips (although i just bent the bracket supplied to fit on the clutch lever holding bolts). It was very useful, specially when i had to wire it up to the fusebox.
tldr, guide is awesome, good work.
Old 15-08-12, 01:02 PM   #18
MMN
Hi
i just bought a used pair of Oxford heatgrips from a friendly org'er, and the photo installation guide here is fantastic, but can i run the wire on the right side? Want to mount the controler put of sight, on the piece of bare frame, near the headtube, under the fairing, right side.
Old 15-08-12, 01:22 PM   #19
muzikill
muzikill's Avatar
Good timing of this thread coming back.
Old 15-08-12, 07:59 PM   #20
punkyp
Reminds me, need to look at the heated grips on my bike. Either they are broken or I can't work out how to switch them on
Independentphoto Hotgrips guide - THANKS Baldyman SV Talk, Tuning & Tweaking 0 19-12-08 04:24 PM
New-style oxford hotgrips gettin2dizzy Ancillaries 3 26-09-07 03:05 AM
Oxford hotgrips Fearg Ancillaries 2 15-01-07 12:26 AM
Oxford Hotgrips Les SV Talk, Tuning & Tweaking 3 05-06-05 04:17 AM
Oxford Hotgrips Les Bikes - Talk & Issues 9 19-10-04 07:26 AM
