Old 22-07-08, 01:54 PM   #11
keeny90
Default Re: Idies, are these llegal???
i would remove them, as it may look confussing from behind?
I was thinking the same plus they kind of pointless now the standard ones are on O well
next mod
Old 22-07-08, 01:57 PM   #12
keeny90
No they are still illegal despite there being proper indies
The Construction and use regulations define the colour of the rear light/brake light red and bright red. a minimum distance between indicators, colour of indicators and flash rate.
simply disconnect the indicator function and you should be OK.
Ahhh i see thank you
kinda sealed the deal with that one then they as good as D/C
Old 22-07-08, 02:00 PM   #13
hovis
stick um on ebay..............
some muppet will buy them
Old 22-07-08, 02:05 PM   #14
lily
Drew has got those but the pointy version ( i also want a set for mine)...... but he has also put mini's on so got both going.....
not had a problem as yet and the local garage said they would pass it on it's MOT due to some new cars now have indicators within the break light.
Old 22-07-08, 02:09 PM   #15
G
I wouldnt dismiss them, theres plenty of people riding about with illegal stuff on their bikes, exhausts, number plates etc.
Ride it out, see if you get pulled, it will only be a £30 fine when you do so I wouldnt worry about it.
If you like them, then keep them.
6.67300 × 10-11 m3 kg-1 s-2
Old 22-07-08, 02:28 PM   #16
timwilky
timwilky's Avatar
It is not the fact the indicators are integrated into the rear light that is the problem. It is the minimum distance apart (I think 240mm) that is the issue.
I also think, but do not have a copy of C&U any more that you are required to maintain a separate red light and cannot alternate it with the amber indicator
Not Grumpy, opinionated.
Old 22-07-08, 02:29 PM   #17
timwilky
timwilky's Avatar
I work on the principle, why give plod a reason. Legal plate, legal exhaust.
Old 22-07-08, 02:33 PM   #18
Lozzo
I work on the principle of:
'the local plod can't be ar5ed to do their job properly and pull bikers - they prefer to support the use of speed cameras and have cut the number of traffic officers/cars, so I'll put what I like on my bike cos there's no-one to notice it any more'
Old 22-07-08, 02:37 PM   #19
G
+1
There not many people riding about with a 100% legal bike unless its standard...nearly every bike you seen has an exhaust without baffle for example.
I'll do as I have always done and take my chances.........but avoid wales lol
Old 22-07-08, 02:45 PM   #20
hovis
but avoid wales lol
and miss out on all our great roads?
the police are not as bad as people think (not in south wales anywho)
Integrated rear light and indicators - legal? dual-power sv Bikes - Talk & Issues 20 05-04-09 02:35 PM
Art.......legal? jumjum_0214 Exhausts 10 20-02-08 05:58 PM
is this legal jans1971 Bikes - Talk & Issues 10 03-02-08 02:55 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
