Old 07-02-10, 01:30 PM   #771
coxxy
Default Re: sv650 stripped and being cleaned/polished
Definitely replace bearings, dust seals and spindle if you have the dosh - whilst its all apart may as well do the whole job? Also dont forget to put the spacer (between bearings) back in before pressing the bearings back. Grease the spindle and away you go.........................You may have a dodgy can of lacquer there or a cheaper version - Halfords rattle cans definitely produce a finer spray - read the can for temp etc
Old 07-02-10, 01:33 PM   #772
allantheboss
Replace all 5 bearings? (Sprocket too?)
Old 07-02-10, 01:52 PM   #773
I wouldn't bother unless they feel rough myself.
Old 07-02-10, 03:02 PM   #774
baldricc
yes its called blooming it when it sprayed in too cold temperature
Old 07-02-10, 03:05 PM   #775
Dave20046
Dave20046's Avatar
If you put the can in a bucket of warm water and put a blow heater or something in your garage you can minimize the risk.
Old 07-02-10, 05:12 PM   #776
coxxy
I guess if you are on the road riding and they are cruddy, worn or just old then yes replace the lot to be sure. If they seem ok and the spindle looks free of wear then you could just clean them out and coat with grease - difficult to tell without looking first hand. Most racers would replace them at the end of the season anyway as a bearing failure can spoil a weekend. If in doubt get a second opinion?
Old 08-02-10, 10:57 PM   #777
-Ralph-
Beautiful result Liam!
To save me reading through all these pages, what did you use for the engine paint?
Old 09-02-10, 12:07 AM   #778
joshmac
Originally Posted by liamsimpson View Post
believe it or not mate its actually that engine paint from halfords and is touch dry in about 20 mins (depending on how thick it is) and 2 hours 2 cure! so not bad i suppose. looks good though and the only reason its painted is because you can't get inside them to polish!! looks quite good though.
HTH
Old 09-02-10, 08:04 AM   #779
-Ralph-
Originally Posted by joshmac View Post
hth
thanks!
Old 09-02-10, 05:05 PM   #780
boot
I've seen it done, and was surprised how good it looked.
stripped heads Wideboy Bikes - Talk & Issues 10 08-07-08 09:15 PM
Help - Stripped Thread!!! Alpinestarhero SV Talk, Tuning & Tweaking 22 17-11-07 11:58 PM
SV650 (99 Curvy Model) STRIPPED! CrazyPassenger For Sale - SV's and SV related items 41 06-11-07 12:44 PM
Cleaned and polished! muffles Photos 13 12-09-06 09:00 PM
All cleaned & polished Robbo_ SV Talk, Tuning & Tweaking 4 12-09-05 08:02 PM
