#11 |
Right, so to simplify things, and confirm my understanding.
If I fit front and rear LED indicators, to solve the flash rate I can use 1 x 25w 7.5ohm resistor per indicator, so 4 for the bike. But I can put 2 of these resistors on either end together, per side. IE I can put no resistors on the rear indicators, then 2 in parallel on the Front Left, and 2 in parallel on the front right. I can put them either way around, and just in parallel to one of the wires from the indicator? As maplin do not list anything over 10 watts I can double up and use a total of 8 for the bike, 10 watt 15ohm. Can I then put 4 of these at each front corner? Is this going to have heat problems? Part no H15R http://www.maplin.co.uk/module.aspx?...=2181&doy=29m5 Or is there a plug and play relay for the K4? |
Small problem with my built in indys | sv-robo | SV Talk, Tuning & Tweaking | 4 | 14-04-08 04:36 PM |
Mini Indys | Mike2165 | SV Talk, Tuning & Tweaking | 6 | 10-01-08 09:29 AM |
LED Indys | ukhammy | SV Talk, Tuning & Tweaking | 1 | 30-12-07 05:14 PM |
l.e.d indys | james160987 | SV Talk, Tuning & Tweaking | 10 | 27-10-06 06:48 AM |
Short or long stem indys? | TC3 | SV Talk, Tuning & Tweaking | 5 | 28-11-05 03:34 PM |
