Old 16-10-13, 06:37 PM   #1
Default Projector HID's
stripped the headlight off the bike to inspect why one hid was not working and i have a burnt out connector... so i'm fitting the projector hid's i had lying around and never got round to as i melted the last headlight unit in the process. this time i have got the headlight apart using a heat gun and the big 3'' halo with proper UK beam pattern projector hids fit
it'll take me a few days to get them all together as the hid units are a bit heavy for the bulb springs so i will have to screw the plates in. i also need to drill a hole for the other cables to exit the lens unit.
Old 16-10-13, 06:49 PM   #2
Default Re: Projector HID's
Should look cool, and less blinding
Have you abandoned the naked idea then?
Old 16-10-13, 06:53 PM   #3
naked still on the plans (maybe) but i thought i would play with the projectors since i have them. if i like the results i might just stay faired....
Old 22-10-13, 05:59 PM   #4
wiring harness complete, everything works as should. just need to liquid metal the unit holders into the recesses, paint the reflectors matt black, stick it all together again, and set the beam pattern then fix in place.
Old 22-10-13, 06:10 PM   #5
Pics!
Old 22-10-13, 07:24 PM   #6
Be interested to see some beam shots
Old 22-10-13, 08:40 PM   #7
pics will come, i need to get a camera first... lol
i'll pop into asda 2morra and get a camera.
Old 28-10-13, 04:21 PM   #8
blackened out the reflectors as it was causing to much scattered light.
i also done the same to the side lights as i'm using LED projector ones.
just need to wait on paint drying then assemble, set beam pattern and put glass back on.
Old 28-10-13, 04:54 PM   #9
how they will look
rather cool i think. but it's not about coolness its about better light
Old 28-10-13, 08:46 PM   #10
Nice! Looks mean
Are they 35W or 50W?
HID's & MOT? SUPERSTARDJ01 Bikes - Talk & Issues 28 21-03-13 06:42 PM
HID's and CCFL red halos Galviniser Photos 56 11-01-13 09:18 AM
Help wiring HID's - High/Low solenoid not working right DarrenSV650S Bikes - Talk & Issues 1 30-06-11 10:06 PM
HD Projector. dill89 Idle Banter 5 20-08-10 01:29 PM
HID's any one got them? Sony Tony SV Talk, Tuning & Tweaking 6 15-04-08 10:54 PM
