#31 |
Just to rebirth a thread.
Husky where do you get the small gasket/ washer for between the 2 halfs and who you using for seals?
#32 |
wemoto mate- i bought a job lot of original suzuki seals a while back from a bike shop that was shutting -you can get cheaper ones on ebay though(originals are 26 quid a set)
#33 |
I think its wemoto job, split me spare and its not looking promising for the seals.
Find out tomorrow when a knock up a piston remover. What size and pitch bolts you replacing the alan heads with.
#34 |
10m x 45 x 1.25 from WVS/FASTENERS ON EBAY
#35 |
Cheers mate
#36 |
The caliper split seal is 69107-34200.
Not separately listed as an SV part, only in the seal kit - but, if you know where to look ![]()
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 21-11-10 at 10:45 PM. Reason: Spelling. |
#37 |
Cheers Sid.
Split the spare and that the only thing needing replaced, and found a crude way to pump out pistons with a foot pump
#38 |
stick to wemoto mate -that oem is 8 quid for the single seal
#39 |
F*** that!!!
Edit 2.48 on wemoto
RIP Reeder 20/07/1988 - 21/03/2012. Always missed squire!!! Every year we meet old friends, gain some new ones, lose old ones and you always remember them all. “Live as if you were to die tomorrow. Learn as if you were to live forever.” Mahatma Gandhi Last edited by andrewsmith; 21-11-10 at 10:50 PM. |
#40 |
Not impressed with fit of aftermarket seal I've seen - I'm sure yours is fine.
GSX-R calipers | Neeja | Bikes - Talk & Issues | 3 | 17-10-09 10:18 PM |
help - facebook mucking up hotmail | CoolGirl | Idle Banter | 8 | 17-04-09 06:27 PM |
Mucking about with carbs | northwind | SV Talk, Tuning & Tweaking | 20 | 07-05-08 06:56 PM |
Calipers | Hogzi | SV Talk, Tuning & Tweaking | 3 | 26-02-06 07:15 PM |
Bled the rear calipers today... | northwind | SV Talk, Tuning & Tweaking | 3 | 25-04-05 06:13 PM |
