#111 |
#112 | |
![]() Yeyy Ruth, the 3 Muskateers me, you and MBK.
<((((((((((((((((◕‿◕) The Woozle woz ere (◕‿◕)))))))))))))))> Black K4 Pointy named Zuky, OEM belly pan, OEM hugger, OEM cowl, R&G bungs, akrapovic system, tinted double bubble Fabbri screen, tail tidy, scottoiler, alarm, datatagged, lowered seat for short ass rider named Shell. ![]() RIP PC David Rathband sad day 29/2/2012 |
#113 |
LOL! Night Shellyl, have a good shift MBK!
Thanks all again! Baph included! ![]() |
#114 | |
As has been explained before, the Throttle Position Sensor, (unsurpisingly), senses the position of the throttle, the display in 'dealer mode' is a voltmeter, the throttle posistion is indexed as a voltage (I don't know, don't care and it doesn't matter what that voltage is), this voltage informs the FI system of the throttle position. It doesn't 'put more fuel in at 3000 rpm', injector duration is controlled by many factors of which throttle position is only one. New bikes are rarely wrongly set, however the initial wear on the components affecting the setting changes it, sometimes quite dramatically, early on in the life of the bike. Very generally speaking after the initial reset the setting doesn't change dramatically thereafter. PS. We've been here before.
#115 |
Why yes we have (hence my comment direct to you before
![]() C'mon Mr Squid, are you really going to be that picky over wording? I did say I'd dumbed that post down. Yes, there are factors that would reduce injector duration whilst throttle index voltage is raising, thereby counteracting the affect of the TPS, but... meh, this is getting old even for me. ![]() I still have fond memories of the conversation we had about it at the AR. ![]() |
#116 |
sorry to hear bout your crash, its not nice, im still recoverin from gettin hit my a van 2 wks ago,my confidence is really low but ya cant keep of the bike forever. when i recover and get another bike then ,as im only in sileby, we can all go on a "help ruth get her confidence back day" bimble .... and me of course... but im crazy and generallly dont give a ****.
#117 |
HAHAH Thank u! Didn't realise there was that many people close by!
Where the TPS is concerned and is now set at 1450-1500 am I ok to leave it there? It isn't gonna shot off, or jerky as soon as i find the bite and let the clutch out (slowly) ????? |
#118 | |
![]() Let the clutch out nice, slow & smooth, and it won't jerk you around. Promise*. *I cannot be held accountable should that statement turn out to be fictitious owing to the fact I haven't seen/inspected the bike in the flesh, nor am I qualified to do so should the opportunity arrive. ![]() |
#119 | |
I can't stress this enough: The TPS doesn't do anything magical, it simply tells of throttle position and is one and one only of the inputs to the FI system, the oft repeated 'puts more fuel in at whatever rpm' couldn't be less accurate.
#120 | ||
Warning Harsh words warning...
I've ridden half a dozen or so pointy SV's none of which have had a "jerky" throttle. Try as the others have said relaxing your grip on the bars because it sounds like your holding on to tight and making big changes in the throttle position rather than small continuous adjustments. You'll get it eventually, you just need to practise, relax and stop over thinking what you are doing all the time.
What will happen to the org? | NAPA121 | Idle Banter | 35 | 18-10-08 05:58 AM |
The "Are you gonna be at soho this friday as paws is gonna be there" thread | Paws | Soho Massive | 59 | 28-01-08 08:30 PM |
Should have said hello sooner - newbiee | Birchwood | Idle Banter | 16 | 19-09-07 04:39 AM |
Well it was bound to happen sooner or later (Rectification notice) | Davies | Bikes - Talk & Issues | 8 | 14-08-07 05:11 PM |
It was bound to happen sooner or later.... | CoolGirl | Idle Banter | 18 | 24-04-06 09:06 AM |
