Old 10-09-08, 05:47 PM   #1
petevtwin650
Default Discussion about s/hand part prices.
Ok rather than de-rail Lissa's thread, here's where we can discuss the cost of bits I'm going to sell. Some people thought that we could sell the bike for the same money as breaking it. so bear in mind that as a pretty standard SV, with 27k, a running problem (carbs), nearly every panel showing a mark, the need to source another exhaust (loft has eaten a downpipe), I reckon we'd be doing well to get 1500 quid. But in bits I feel it's worth 2500. I realise that not all bits will sell. Who actually wants a frame? And my prices may be optimistic, but hey ho.
Full list below. Please note this does not include all the trick bits, TI Akra exhaust, machined top yoke, new fuel tank and the 3 fairing panels (all in Grand candy Blue of course, new Braking wave rear disc, new reg rec, two racks, Ohlins rear, seats, tank cover and bag, chrome side panels, and rear sets.
£400 Engine 28,000 miles just had a 15,000 service and JHS cams fitted. 74 bhp with rotten carbs.
£250 Frame with V5. Straight, never been involved in any sort of accident.
£200 Forks straight with polished lowers and fitted with preload adjusters. Can be sold with Racetech Gold emulators and .90kg springs. Just been serviced at JHS with new fork oil. An additional £100.
£100 Racetech springs and .90kg springs
£350 Purple powdercoated wheels with Braking wave wavy discs, titanium disc bolts and good Pilot road 2 Tyres.
£100 Fuel tank. No filler cap. Good apart from one small chip that's been on there since we got it.
£75 Instruments. All working. Speedo Showing 27742
£50 ea Left and Right Fairings. Left has scuff from wall
Right has small crack underneath indy where the previous owner dropped the bike.
£50 NoseCone. Pretty perfect .
£40 Powerbronze Bubble Bubble Iridium screen. Good
£15 ea Mirrors. Scuffed backs.
£40 Front subframe. Straight
£75 Uk spec light unit.
£50 OEM Top and Bottom Yolk
£20ea Clip Ons
£10 Pair of Stainless Bar ends
£70 Gixer Radial master cylinder
£50 Lock Set with two Keys, Filler ,Ignition Switch and seat lock
£30 OEM Seats. Not ripped or anything.
£10 ea OEM Rear brake and Gear lever
£30 ea Left and Right Riders Hangers complete with pegs
£75 Roca Belly pan. Needs a respray due to stonechip damage
£25 Front Mudguard with Fender extender. Small crack and slight damage where brake fluid has dropped onto it.
£20 Pair of rear pillion hangers and pegs. Hangers powdercoated Blue
£10 Powdercoated blue Torque arm. Chipped.
£10 Powdercoated blue rear caliper hanger
£35 Rear caliper
£15 Rear master cylinder, polished.
£25 OEM Rear shock. Under 1500 miles
£15 OEM Dog bones the pair
£40 Suspension linkage. Was serviced at JHS recently
£30 Rear subframe. Straight.
£5 OEM Rear light
£30 Seat plastics complete. Worn by boots but polishes up nicely. Cracked where i forgot about the little self tapper, and the black joiner piece is marked when Rentec rack came loose and rubbed against it
£10 Grab Rail
£75 Radiator. The thermo switch doesn't work, therefore the fan doesn't switch on when it should
£30 Rad Fan. Working
£10 Speedo Drive
£10 Reg Rec. It's the original!
£40 ECU under the rear seat.
Old 10-09-08, 05:53 PM   #2
rob13
Default Re: Discussion about s/hand part prices.
Pete I would say the engine is probably optimistic. I have seen lesser miles (pointy engines too) going for less. You might be able to get a bit more for pegs and levers as theyre pretty expensive to buy from somewhere like Robinsons foundry.
I totted my SV up before selling it, and worked out if I sold it in bits I would get about £2k for it, but the tank and forks were damaged.
Old 10-09-08, 06:01 PM   #3
Sean_C
I wouldn't say the engine is too optimistic, it's just had JHS cams put in for starters. Not much work and it'd be a corker.
Though the wheels are optimistic- they are purple after all. What condition are the wave discs in? Is it not worth splitting them from the wheels?
I don't think you'll get 75 for the clocks- you see them on eBay for that and they never sell.
What about your loom?
Edit: Roca bp for 75 quid (including the fitting kit) is a bargain, I'd say.
Old 10-09-08, 06:02 PM   #4
The cams are worth a lot, though.
Old 10-09-08, 06:06 PM   #5
drag
*pitches tent for top yoke*
Old 10-09-08, 06:21 PM   #6
It's the best top yoke I've ever seen
Old 10-09-08, 06:29 PM   #7
petevtwin650
The wheels are something that people may have seen and would like on their curvy Sean. The bolts alone cost 75 quid. However the discs have been on for a long time. Still servicable as I didn't use the front much. Only changed the pads once. The rear is ok too. Plus the front PR2 has got about 4k in it and the rear maybe 2K.
As for the loom. I thought that would be one of the bit's I'd end up with.
Old 10-09-08, 06:42 PM   #8
rob13
The speedo drives usually sell for more than £10 dont they?
Wheres the light unit??
Old 10-09-08, 07:02 PM   #9
Sean_C
Sorry pete, being a numpty I forgot the appropriate smiley after the puprle wheels comment.
You may end up with the loom, but equally if you don't price it silly it may well go. I've just bought a naked loom off ebay for 25 quid posted, and there were other S looms priced for silly money- some for 60 or 70 quid.
Old 10-09-08, 07:05 PM   #10
hovis
? why
AR Marking Discussion fizzwheel 2009 Annual Rideout 149 09-08-09 10:59 AM
TL Discussion Thread dizzyblonde Bikes - Talk & Issues 108 26-09-08 06:37 PM
Ducati - Discussion... plowsie Moto GP 48 25-06-08 10:58 PM
left hand lower and left hand tail piece malks Stuff Wanted 2 02-06-08 09:56 PM
General Discussion rubberduckofdeath SV Talk, Tuning & Tweaking 11 05-08-04 08:52 AM
