Old 05-04-10, 08:15 PM   #151
Default Re: TPS Adjustment Step-by-Step Pictorial Guide
M5x10 IIRC but wait for soemone to confirm that.
Old 05-04-10, 08:31 PM   #152
barwel1992
ok cheers
and will do
Old 05-04-10, 08:50 PM   #153
Nobbylad
Nobbylad's Avatar
Can't you take one out of yours and measure it?
Old 05-04-10, 08:58 PM   #154
barwel1992
not without replacing them, the one i replaced the head went putting it back in, found it lying around and its just as soft as the originals, and the original one is also buggerd
so want to order new ones before i remove them
Old 06-04-10, 11:37 AM   #155
cF^
Wow, can't beleive I've only just found this thread. Will give this a go as soon as I've got an hour to spare. Why isn't this stickied??
Old 24-04-10, 02:21 PM   #156
Willcat
Just done mine, made quite a difference, really a must-do adjustment!
Didn't bother get security torx bits, just undid the top one slightly using pliers and a few knocks on the sensor with a mallet. A bit brutal but did the job, now it goes up at 1500rpm.
Old 24-04-10, 07:45 PM   #157
davepreston
ahhhhhhh but is it the same with the thou
Old 24-04-10, 07:47 PM   #158
barwel1992
^ think so dave, lots of people on svrider with thou's and they sead it worked but not 100% on what they did and if its the same
EDIT hear you go http://www.suzukisv1000.com/faq/tps.htm
Old 25-04-10, 10:24 AM   #159
Yes. SV1000 is the same.
Old 23-05-10, 07:37 PM   #160
watsontrio
Had a ride on my bro's pointy earlier and felt odd compared to my curvy so a quick search and 20mins later job done. He said it's transfomed his, it was at 3800rpm.
Cheers chap!
step bump hang man Idle Banter 3 12-10-08 04:53 PM
Trying to be green - a step too far Ed Idle Banter 2 02-06-08 11:21 PM
sv650 to a fz1 is it to big of a step up jans1971 Bikes - Talk & Issues 30 28-11-07 02:44 PM
Big Brother's next step? jonboy Idle Banter 5 20-03-06 03:42 PM
What's the next step? MaxSuzuki SV Talk, Tuning & Tweaking 9 10-07-03 10:48 AM
