Old 26-09-12, 10:17 AM   #251
SV650Racer
Default Re: TPS Adjustment Step-by-Step Pictorial Guide
^ no it wont affect the PC at all.
Old 29-09-12, 05:46 PM   #252
Jayneflakes
Jayneflakes's Avatar
I have just done this check and discovered that my line moved at 4.5K! The difference is amazing.
On a side note, I replaced the rubbish Suzuki Bolts with Stainless steel Allen Head bolts. So much easier to adjust.
Jayne you're a Pussy Magnet
Old 29-09-12, 06:18 PM   #253
it's taken you this long to do it
Old 29-09-12, 08:05 PM   #254
Jayneflakes
I was scared!
When it came to it though, I just took the wife's Lap top down the garage and had this thread on call the whole time. Fabulous help it was too. I cannot believe in the difference this has made, Sylvie has got a little more spirited on her take offs!
Old 29-09-12, 08:46 PM   #255
i have recently set mine just off tickover. basically as soon as i turn the throttle. so far (1000 miles) no adverse effects and it even smoother.
Old 29-09-12, 09:34 PM   #256
Jayneflakes
Now this looks better.
Old 29-09-12, 09:51 PM   #257
TicklinJock
TicklinJock's Avatar
Thanks to all for this!
I moved mine from 3100 to 1800rpm in June. I was getting a stutter when reapplying throttle in bends - this seems to have improved. Also picks away a wee bit more torquey and smooth.
I was concerned it would increase fuel consumption but it seems to be just the same.
TicklinJock is offline   Reply With Quote
Old 29-09-12, 10:44 PM   #258
get it further down than 1800 and its a lot smoother. it takes patience but it's worth it.
Old 10-12-12, 01:06 PM   #259
phil24_7
With the wifes bike set down that low its running v v rich and is checking muchos fumage out the can!
Is it possible that the bike has been tuned and so this adjustment won't work?
Old 10-12-12, 01:10 PM   #260
nope. tps is needed for the brain.
what's the bike idling at?
step bump hang man Idle Banter 3 12-10-08 04:53 PM
Trying to be green - a step too far Ed Idle Banter 2 02-06-08 11:21 PM
sv650 to a fz1 is it to big of a step up jans1971 Bikes - Talk & Issues 30 28-11-07 02:44 PM
Big Brother's next step? jonboy Idle Banter 5 20-03-06 03:42 PM
What's the next step? MaxSuzuki SV Talk, Tuning & Tweaking 9 10-07-03 10:48 AM
