Old 30-04-13, 07:49 AM   #271
aesmith
Default Re: TPS Adjustment Step-by-Step Pictorial Guide
Originally Posted by Ginja_Joe View Post
Can anyone link me to where I can get a 6 pointer from?
This is the one I bought ...
http://www.ebay.co.uk/itm/3008585283...84.m1439.l2649
Did the trick for me. If you're really stuck, PM me your address and I'll post mine to you, together with a couple of suitable Allen screws to replace the originals.
Old 30-04-13, 08:13 AM   #272
Vinc
Got mine from screwFix
Sent from my HTC Desire using Tapatalk 2
Old 30-04-13, 08:23 AM   #273
dirtyred619
Got my handy little set from Machine Mart.
http://www.machinemart.co.uk/shop/pr...-proof-bit-set
Old 30-04-13, 12:34 PM   #274
Ginja_Joe
Thanks guys. I'll grab the bit off eBay.
Old 08-05-13, 05:38 PM   #275
veenee
I have done mine today, I am very pleased with the result. Much less jerky! I got used to using the clutch, so now I have to get rid of that habit...
It was set up at about 3500 rpm and I managed to get it down to 1500, so there is quite obvious difference.
No problem with cheesy screws though - I got this set and it worked like a charm:
http://www.silverlinetools.com/products?search=633840
Paid £6.39 on eBay...
oh, I also used insulated paper clip which works great as it snaps in perfectly
Old 08-05-13, 05:52 PM   #276
Ginja_Joe
The recommended bit from eBay worked a treat and the adjustment has made a massive difference. Went from about 4200rpm to 1900.
Pleased!
Old 17-05-13, 06:45 PM   #277
shiftin_gear98
shiftin_gear98's Avatar
Finally got round to doing this today, wish I hadn't put off doing it for so long.
Took 20 mins from start to finish!
Couldn't believe it when the line didn't move till 4200. WTF Suzuki.
Guess mine was assembled at 4.45 on a Friday! Now moves at just under 1500.
Can't wait till Monday to try it. If you haven't done this yet, please do. Peace of pish!
Old 17-05-13, 07:00 PM   #278
Runako
Just to clarify. Is this necessary for the K7+?
Old 18-05-13, 08:59 AM   #279
It will have been right when it was built. This is not a modification, it's an adjustment, things change - if they didn't adjustment wouldn't be needed.
Old 18-05-13, 09:13 AM   #280
aesmith
I notice that the TPS is on the rear throttle, so any change in the linkage between the two is going to change the TPS setting. Such changes will come when the TB balance is adjusted, or by wear in the link. I wonder why they didn't put the sensor on the front TB.
step bump hang man Idle Banter 3 12-10-08 04:53 PM
Trying to be green - a step too far Ed Idle Banter 2 02-06-08 11:21 PM
sv650 to a fz1 is it to big of a step up jans1971 Bikes - Talk & Issues 30 28-11-07 02:44 PM
Big Brother's next step? jonboy Idle Banter 5 20-03-06 03:42 PM
What's the next step? MaxSuzuki SV Talk, Tuning & Tweaking 9 10-07-03 10:48 AM
