Old 20-09-14, 02:28 AM   #301
Coderedpl
Junior Member
Default Re: TPS Adjustment Step-by-Step Pictorial Guide
Originally Posted by aesmith View Post
The adjustment won't be affected by a change of plugs. Doesn't do any harm to check of course.
Cool, thanks!
Coderedpl is offline   Reply With Quote
Old 22-09-14, 06:30 AM   #302
Corny Gizmo
OMO,
checked mine last night and found it to be reacting at around 4200 RPM, the bike is only 6-7 Months old, is this something that goes out of spec over time or is it something that just hasnt been set correctly from factory?
Also, do any of the services cover adjustment of TPS? I find it hard to believe that we are supposed to do this ourselves.
I have not adjusted it yet as I want to get the proper tool so I don't kill the bolts
Old 22-09-14, 07:30 AM   #303
aesmith
The Suzuki service procedure just checks that the line is in the middle at idle, it doesn't check the threshold at which it moves up. I guess the same applies to the factory setup.
It will be prone to go out of spec with time since it's driven off the rear throttle body via a mechanical linkage. Will also change (I think) if the throttle bodies are balanced.
Old 22-09-14, 08:22 AM   #304
Corny Gizmo
Thanks for the info aesmith, I have got my 7.5K service on Friday so ill adjust the TPS after that incase they touch the throttle bodies etc.
Old 22-09-14, 11:58 PM   #305
they wont touch the TB's unless you specifically ask them to do a balance and even then nothing will be disturbed if they do. you can safely go ahead and set the TPS.
i have been testing out a new method over the past 2 years of setting the TPS just to make sure that no damage will occur. my new method is to set the TPS so the line just moves as you set it and when you tighten the bolt is settles in the middle. no turning the throttle to see what revs the TPS is kicking in at. this makes the TPS active the moment you turn the throttle and the result is complete lack of snatchyness but you get engine braking more along the lines of an inline 4 which makes for a very smooth bike.
Old 23-09-14, 07:53 AM   #306
Corny Gizmo
It sounds exactly what I was thinking Bibio, as it moves anyway when tightening up I planned to do exactly what you detailed above e.g over adjust to account for movement when tightening.
I'm excited to see if this reduces engine brake as much as you say, as I do a lot of two up riding (every day) having to iron the snatchyness and engine braking out with the clutch is getting tiresome
If I get chance tonight I'm doing it, I shall report back
Old 23-09-14, 11:11 AM   #307
Soapysoap
Just did this today after eventually finding my Dealer Mode plug (Thanks Corny).
Bike is a 2013 model and I thought it was my lack of finesse that made the bike "jerky". Mini roundabouts required constant slipping of the clutch.
After a ride out on my mates GSXR600 I found it so much easier to ride (even though I felt like a circus elephant on a tricycle). So my choices were to see if my SV could be made better or look at getting a different bike when I can afford it.
Followed the instructions and found warmed up and at idle it was on the bottom bar then swiftly moved to the middle bar about 1400rpm then went to the top bar at around 4500rpm.
Cracked off the tps torx screw then tapped the sensor anticlockwise. Managed to get to go down in about 700rpm increments. Tightened back up bar was then at the top at idle. Tapped back the other way and got the bar to move about 1350 rpm (idle at 1250). Boxed everything up and went out for a ride.
\Just got back and.......what a difference. Like people have said it seems a lot smoother. No slipping of clutch required. I also feel as though the engine braking isn't so severe. Really transformed the bike for me.
Great thread...Thanks
Old 23-09-14, 07:35 PM   #308
rickylp
Stupid question but after loosening off the top torx screw is it then possible to just loosen the bottom just enough to be able to gently tap the top around in tiny movements rather than have it really loose and then have it moving too much?? sorry if this a dumbass question but i dont know the answer???
Old 23-09-14, 07:43 PM   #309
that's exactly what you want to do.
Old 23-09-14, 07:50 PM   #310
rickylp
Perfecto! cheers Bibio, gonna give it a go tomorrow i think. Was riding today and consciously looking at the rev counter as i rolled on the gas to see when it was reacting and i reckon its about 3500-4000rpm!
step bump hang man Idle Banter 3 12-10-08 04:53 PM
Trying to be green - a step too far Ed Idle Banter 2 02-06-08 11:21 PM
sv650 to a fz1 is it to big of a step up jans1971 Bikes - Talk & Issues 30 28-11-07 02:44 PM
Big Brother's next step? jonboy Idle Banter 5 20-03-06 03:42 PM
What's the next step? MaxSuzuki SV Talk, Tuning & Tweaking 9 10-07-03 10:48 AM
