Old 14-07-08, 09:07 PM   #21
Grinch
Default Re: Fitting a ZX636 shock - what will I need?
You should have load of clearance to get a huge shock in there, sounds all very odd to me.... though maybe not as I had my subframe off when I fitted mine. Maybe removing the whole suspension linkage would help.
Old 14-07-08, 09:37 PM   #22
thefallenangel
copper grease all the dogbones up as all the bushes had no grease on mine after 6000 miles.
My GSXR shock went on but it took a lot of butchering the battery box. Paddock stand to get the rear wheel out and axle stands under the rear sets to hold it up. Should all be very accessible.
Old 14-07-08, 10:24 PM   #23
mattc
That shock looks Identical to the shock I put in my curvy, it was a Showa unit from a ZX636 C1H, works well.
Old 15-07-08, 09:12 AM   #24
dyzio
dyzio's Avatar
the c1h is the one i have.
how did you feed it? or how much of the battery box did you cut out?
Old 15-07-08, 10:53 AM   #25
Just to clarify here you do NOT want to use copperslip in the bearings! Clean them up with parrafin or petrol and a rag, then work in a good high melting point grease untill they're as packed as possible. You can clean up the inner race with a little scotchbrite. A little copperslip on the threads of the bolt is all you need so it'll come off next time.
Old 15-07-08, 11:09 AM   #26
dyzio
dyzio's Avatar
Originally Posted by mattc View Post
And I'd threadlock all the bolts.
Old 15-07-08, 11:13 AM   #27
Take your pick. I've always copperslipped them, never had one come loose, they won't if torqued up.
Old 15-07-08, 11:37 AM   #28
dyzio
dyzio's Avatar
YC, how much of the battery box do you have to cut to fit it? the whole bottom part and rest the battery on the reservoir?
Old 15-07-08, 11:44 AM   #29
Sitting the battery on the reservoir isn't a good idea. I had to trim the base of the box and part of the LHS of it. Make some little spacers to sit the battery on, then chuck the fusebox tray at a passing chav.
Old 15-07-08, 12:05 PM   #30
mattc
made my own undertray and battery box from 18 gauge steel sheet and welded it into the subframe.
Shocks good with hagon springs and 15w up front, had to back of both compression and rebound damping. Still not got it 100%, just needs a bit more fiddling!
ZX636 shock – my opinion Blue_SV650S SV Talk, Tuning & Tweaking 135 29-09-08 06:25 PM
ZX636 B1H Rear Shock mattc For Sale - SV's and SV related items 6 24-06-08 09:44 PM
ZX636 shock/resale value andyb SV Talk, Tuning & Tweaking 6 29-09-06 09:05 AM
ZX636 shock for a curvy? Michael S SV Talk, Tuning & Tweaking 5 04-01-06 05:00 PM
ZX636 shock Grinch SV Talk, Tuning & Tweaking 20 01-03-05 03:11 PM
