#11 |
I did the same, I bought the maplins one (http://www.maplin.co.uk/Module.aspx?ModuleNo=226501) and then added an inline fuse and two circle battery connections. Cost about £6/£7 depending if you have other parts already or not, plus you can choose how long you want it.
I did think about making them to sell on eBay / Forum but too much hassle I think, lol. ![]()
Black K8 Sport (Will be missed) SV650 Slogan TShirts & Hoodies Elevated Photography Specialist : HiCam Photography Services |
#12 |
Evel Knievel
did mie exactly the same as cbay....... mouthed on the front subframe, nicely tucked away and sheltered from the weather......... i took the plug apart and sealed it back together with black silicone but even still i have accidentally filled the plug up with water whilst washing and done no harm
#13 | |
Large Member
How's that done then? And put it in REAL SLOW speak cuz I fik
How to amuze an idiot: Look right-> <-Look Left |
#14 |
On a suitably rated relay all you do is...
It will have terminals which you feed the positive to... an open (N/O) (or closed circuit, depending on type of relay, N/C) basically this is just a break of contacts which close (or open) when energised, Symbol normally looks something like this ./' or ._. A positive signal or switched live and thats it, i took mine from lighting circuit. Feed the positive directly from the battery with an inline fuse preferably to the one side of contacts or whatever it is on relay, other side goes to feed to the cigarette lighter, make sure its a decent size cable as well, something around 2.5mm Sq multi strand. You can take the negative from battery also (you'll need to supply both relay and cigarette lighter with a neg) Take signal from lights or another ignition 'on' only source and feed the relay (this is the one that energises the relay) Thats it really, i could show you in 5 mins, lot harder to explain in text. By all means if you wanna call me when you're doing it and i can help over phone, but its very easy once you understand the symbols on the relay. Last edited by Specialone; 19-02-10 at 06:52 PM. |
#15 | |
#16 | |
Factory ones will be stand alone as well. Horses for courses, i prefer to do it my way cos i know it wont give me any grief. |
#17 |
If i fitted one of these and connected it directly to the battery and left it without anything plugged in would it still flatten the battery, and how long would that take??
#18 |
Nope it doesn't drain the battery, as nothing is plugged in their is no power being pulled out.
My ready made one is still working perfectly and used on almost every ride, very simple and I know there are better ways to install one (i.e. not directly connecting it to the battery) but as long as I don't forget to unplug anything that's in, I have no reason to mess around with anything better. |
#19 | |
Thats the risk you have though, directly to the battery, my way you cant. But as long as the socket has no LED on it or anything then it shouldnt affect the battery at all if there is nothing plugged in. |
#20 |
Awesome think one of these is in order then!
Just added a power socket | TC3 | Bikes - Talk & Issues | 15 | 12-07-09 09:52 PM |
Fitting cigar socket - power from where? | harvy | SV Talk, Tuning & Tweaking | 8 | 22-06-09 06:55 AM |
Wiring a power socket? | DEJA_Vu | SV Talk, Tuning & Tweaking | 7 | 02-02-09 12:18 AM |
Fitting cigarette socket | cb5_keith | SV Talk, Tuning & Tweaking | 44 | 12-07-08 09:19 PM |
12v power socket? | Baldyman | SV Talk, Tuning & Tweaking | 14 | 20-05-05 04:55 PM |
