#61 | |
You should fit an inline fuse to the grips because they are probably rated lower than the horn and the horn fuse will be too high. Put the fuse between where you solder the live into the horn circuit and the grips' switch. Most horn feeds are permanently live and the circuit is made in the neutral, for some strange reason. |
#62 |
ta .. what size fuse? 10?
#63 |
#64 |
ok i chucked the instructions away .. oops I will find out
thanks |
#65 | |
#66 |
Fit mine today, straight to battery, took about 5 mins. Tested, works great!
Least I can keep my phone charged over the AR ![]() |
#67 |
thanks all for your help..
all done now.. one neatly on my top fairing and another on the side panel right side on an extension all enat and lovely . and I have done the heated grips to a switch live now. so ta |
#68 | |
Firstly - what contacts are you on about in the first paragraph? I will assume you mean ignition switch contacts. When the socket isn't being used there is no current draw so there is no load, therefore no additional strain on switchgear or contacts. If anythng, adding a relay switched by the ignition just adds more load into the system even when the socket isn't being used, making a switch contact failure more likely, where a no-relay situation is perfectly safe and reliable. Secondly - "only pulling 120 watts"? 120 Watts has a current draw of 10 Amps on a 12 Volt circuit. I would very much doubt that a Tom Tom of any decription pulls anywhere near that amount of current. Your socket is rated at 120W as well, so it should be well up to handling current of 5-8 Amps at 12 Volts easily. |
#69 |
I think lozzo when i first wrote that i hadnt absorbed or read and took in the 120 watts thing properly, later on, i did, so a mistake on my part there
![]() BTW i did mean the ignition circuits, if you have something plugged in pulling a lot of juice you are increasing the switching load for that circuit, im not saying it will fail, but if its being asked to switch an additonal 10 amps than 'normal' then its possible. You dont operate the horn while starting the bike do you? You have yours wired directly to battery anyway so we really shouldnt be still talking about this should we? Also, there is no additional load in the circuit using my relay, relay doesnt use hardly anything to switch, you could do it with alkaline batteries easy peasy. You will never convince me that my way is not required, ultimately, its my bike, i want a relay on it, so we'll leave it there. If it was directly fed to the battery then fair enough, no issues. Each to their own. Also, my tom tom flattened my transit connect diesel battery when left on charge all day, so it pulls more than you may think. Phil Last edited by Specialone; 04-08-10 at 05:04 PM. |
#70 |
I have had two of the Towzatronices ones and for the price3 and ease of fitment you cant beat them. Mine is tucked away under my seat and chargers my mobile or satnav quite happily, I am very pleased with mine
Just added a power socket | TC3 | Bikes - Talk & Issues | 15 | 12-07-09 09:52 PM |
Fitting cigar socket - power from where? | harvy | SV Talk, Tuning & Tweaking | 8 | 22-06-09 06:55 AM |
Wiring a power socket? | DEJA_Vu | SV Talk, Tuning & Tweaking | 7 | 02-02-09 12:18 AM |
Fitting cigarette socket | cb5_keith | SV Talk, Tuning & Tweaking | 44 | 12-07-08 09:19 PM |
12v power socket? | Baldyman | SV Talk, Tuning & Tweaking | 14 | 20-05-05 04:55 PM |
