Old 22-11-07, 08:52 AM   #21
fizzwheel
fizzwheel's Avatar
Default Re: Cold starting problem. carb heaters?
Originally Posted by peahead View Post
got any info on sorting this out, even if it is this, but above it says k4s dont have a choke or something
As I said above, K3 onwards bikes does not have carbs on it as its fuel injected. It has throttle bodies instead which dont work the same way. Your leading yourself up the wrong path by worrying about this its not what your problem is being caused by IMHO.
Sounds to me like your alarm is f*cked, does it have an imobiliser on it ? If so that might be whats stopping the fuel rail from priming which is why IMHO your bike isnt starting because no fuel is getting into the cylinders.
You'ev ruled the battery out, but at this point if it turns over but wont fire then even a duff regulator isnt going to stop it starting at this point if the battery is fully charged IMHO.
If your not mechnical and with respect by the sounds of it your not then I dont think your gonig to solve this by yourself. Instead of clutching at straws I think your going to have to take it somewhere and get it looked at.
I appreciate you dont want to and it can be expensive, but you either want it fixed or you dont and without having the bike in front of you its hard to diagnose problems and I'm not an experienced enough mechanic to advise you further.
You could try dropping a PM to Rictus01 or Sid Squid or Spannerman and see if one of them can help you further.
HTH
Old 22-11-07, 04:58 PM   #22
peahead
HTH
thanks for you help so far mate
ok so if it is my alarm/immobiliser is there any way to bypass it without causing permenent dammage, jus so i can start my bike and see ya kno wht i mean
and yeah your probley right, i should take it in somewhere, probley at the weekend if i have the time and money
Old 22-11-07, 05:02 PM   #23
fizzwheel
fizzwheel's Avatar
You have a meta alarm dont you ? You should have a red code card somewhere that will have the PIN number on it that you need to key into the alarm to deactivate the alarm.
I cant remember the exact sequence but it should be in the instruction manual if you have one, or it might be on their website.
Old 22-11-07, 05:06 PM   #24
peahead
yeah i have a red card, but i kno this goin sound stupid but i dont kno where my alarm is located ha (im useless) should be under the seat or sumthin yeah? but then again i cant say ive seen it, ill look on the internet find wht it looks like then have a ganders
thanks for the rapid response just finished work and straight bakc to this NICE ONE
Old 22-11-07, 05:10 PM   #25
peahead
jus found this just reading now
http://www.visordown.com/forums/showthread.php?t=315264
if u want to check it
Old 22-11-07, 05:10 PM   #26
fizzwheel
fizzwheel's Avatar
It'll depend on the fitter as to where the alarm is, normally the control module is hidden away so its not easy to remove. Sometimes this might be under the pillion seat so thats the first place to look.
If you have the card then you should be sorted. You dont need to actually touch the alarm to disable it. It involves pressing the button on the keyfob and turning the ignition off and on a certain number of times on the Meta
if you get really stuck I have one on my GSXR I'll dig on the instruction manual and post the details of what to do if that helps.
Old 22-11-07, 05:12 PM   #27
fizzwheel
fizzwheel's Avatar
I woudlnt be doing that till I was certain it was the alarm thats causing the problem especially if I didnt know what I was doing.
Find the instructions and disable the alarm before you start messing with the wiring.
Have you got a spare keyfob ? If so try that it might be the battery is flat in the one you are using.
Old 22-11-07, 05:42 PM   #28
peahead
right i have the keyfob, i have the code how do i do it lol
Old 22-11-07, 05:43 PM   #29
peahead
big thanks to u sir for all this help
Old 22-11-07, 07:06 PM   #30
peahead
right i jus found on the net how to dissarm but pfft tried it 6million times am i doin something wrong
Disarming with secure PIN number
• All systems are supplied with a random 5-figure PIN number. This number is printed on the orange remote control code card.
KEEP PIN NUMBER SAFE* as it also required to code additional remote controls (dealer function).
• Familiarise yourself with this procedure.
• Turn the ignition on (the LED will be on)
1 Turn the ignition off within 10s (the LED will flash with an even sequence)
2 Turn the ignition on when the LED has flashed the number of times corresponding to the first digit of the override code
3 Turn the ignition off within 10s (the LED starts a new flash sequence)
4 Turn the ignition on when the LED has flashed the number of times corresponding to the second digit of the override code
5 Continue with this procedure until the entering of the fifth digit.
6 When the fifth digit has entered, if the code is correct, the system disarms.
Warning If an incorrect code is entered 3 times, the system will block all further attempts for 30 minutes. Leave ignition off for this period then re-enter correct code. If the alarm is armed, the system will be sounding during this procedure.
----- for a start when i turn the ignition on it is not on, should i have a permenent light or what. it flashes when the alarm in on and dont even turn on when it aint armed
and will this disarm my immobiliser aswell
Carb Heaters thedonal SV Talk, Tuning & Tweaking 17 08-01-09 03:29 PM
Carb heaters drag Stuff Wanted 5 29-09-08 01:28 PM
Are my carb heaters draining my battery? svrash SV Talk, Tuning & Tweaking 12 27-12-06 11:13 PM
Carb Heaters (again) anyone got the part #? echomadman SV Talk, Tuning & Tweaking 8 12-01-06 06:36 PM
carb heaters rastas SV Talk, Tuning & Tweaking 8 12-03-05 05:19 PM
