Old 31-03-15, 06:49 PM   #111
Default Re: svbits.co.uk showcase
yes if you want one
Old 31-03-15, 08:11 PM   #112
garynortheast
garynortheast's Avatar
Set of the curvy plates for me please Lance. Are you going to try and incorporate a scottoiler nib hanger into them?
Old 31-03-15, 08:59 PM   #113
i will do at some point but my piggy bank will have to recover first. oiler bracket and speedo drive conversion will be at the same time.
Old 31-03-15, 10:25 PM   #114
garynortheast
I'd be very happy to put the money for the bracket up front if it's of any help.
Old 31-03-15, 10:49 PM   #115
not really, its like putting pennies in an empty jar that has to be full.. lol thanks for the offer though
dont worry it wont be too long before the brackets are done.
Old 01-04-15, 06:41 PM   #116
Nutsinatin
Nutsinatin's Avatar
I don't know, if you took pre orders I'm pretty sure you could fill that jar pretty soon! Seriously though, I'm ready and waiting for the pointy swing arm brackets, bike needs more shiney shiney bits!
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 02-04-15, 03:42 PM   #117
aesmith
pointy swingarm bearing play reduction washers in SS
I'd be in for a set of these please, assuming a reasonable price.
Old 02-04-15, 04:13 PM   #118
no probs. they should be cheep but it all depends on what price i get from the profilers.
now, they are not play elimination washers they are play reduction washers. from all the pointy swingarms i have had my grubby paws on the gap is around 1.2-1.3mm off the bike. the reduction washers will be .5mm to take up a 1mm gap so will leave a little play but we are talking .1-.2mm. once the axle has been tightened then some swingarms will have a little binding but bed in and some will still have a tiny little bit of play. either way it will reduce the play in the swingarm considerably.
Old 02-04-15, 10:03 PM   #119
electricheadx
Default Re: Re: svbits.co.uk showcase
I would take a set of these also.
Sent from my SM-N910C using Tapatalk 4
electricheadx is offline   Reply With Quote
Old 02-04-15, 10:29 PM   #120
one other thing about the reduction washers. they are not a cure for worn swingarm bearings and will do absolutely nothing to reduce the pay in worn bearings. the only solution to worn bearings is new bearings and spacers.
