#61 |
You should have a pm from me, im after a pair of your adjuster plates
Craig |
#62 |
Hi Bibio
I'll take the gizno relay PM sent Kam Sent from my iPhone using Tapatalk |
#63 |
i have:
0x curvy and 1x pointy vacuum extensions with or without oilier T 1x pointy swingarm brackets with or without oilier downstand 0x gizmo's 3x powerboxes gives a PM if your interested. Lance |
#64 |
Could I suggest a headlight unit and a front pointy cowl.. ha! ;]
#65 |
you could do but i have a habit of melting them in ovens. lol
#66 |
haha! I don't want a melted on! ;P
#67 |
i have:
1x pointy vacuum extensions with or without oilier T 3x powerboxes gives a PM if your interested. Lance |
#68 |
I'll have the vacuum extensions with scottoiler T. If still available.
#69 |
you may.
#70 |
Finally got my vac extensions fitted. Top job.
Need to watch the length when you cut into the rear hose. I left too much and pinched the hose when I put the tank back down. Slight concern when the bike cut out once the carbs emptied but quickly worked out what I'd done ![]() Just wondered...what's the reason for the reducing T on the curvy kit? |
