Old 20-02-11, 12:55 PM   #11
beabert
Default Re: carb balancers
Originally Posted by loonytoon View Post
sweet cheers dude, does there have to be a certain amount of oil/water?
water with couloring seems a good idea less mess just pour down sink.
cheers
Ben
will be harder to read, check youtube to see what i mean.
V = πr2h
30ml ish of oil i used this to check
http://www.calculatorfreeonline.com/...s/cylinder.php
Old 20-02-11, 09:20 PM   #12
Water having a lower viscosity will probably mean it will jump about more quickly, oil should have some damping effect.
You can get the same effect by closing off the tubes somewhat to limit flow rate. Carbtune uses a piece of capillary tubing in the big tube to restrict the flow to stop them bouncing about
Old 20-02-11, 11:14 PM   #13
loonytoon
i was thinking about that the higher vicosity would help like a dampening affect. or i have some old oil from my last oil change that might do the job as its nice an black so easy to see
Old 20-02-11, 11:17 PM   #14
Careful that doesn't bite you in the *rse, used oil tends to stain clear tubing fairly badly.
Old 20-02-11, 11:21 PM   #15
beabert
Oh your in bham! you can have some of my 2stroke oil and syringe mate dont need it. I can drop some off whenever, always pottering around bham.
Old 20-02-11, 11:35 PM   #16
loonytoon
ok i wont use old oil then bad idea. yes mate im in bham just off hagley road wolverhampton road cross roads.
well it wont be next week as im back up in lincoln for the week but im off for two weeks so will be doing it then
Old 20-02-11, 11:43 PM   #17
beabert
Ahh, i know the place.
Well pm when you want it
Old 20-02-11, 11:47 PM   #18
loonytoon
cool cool will do chhers bud.
may bribe you into helping with cups of tea :P
Old 20-02-11, 11:56 PM   #19
beabert
Sure I'm happy to hang around whilst you do it.
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
Carb balancers and air boxes drag SV Talk, Tuning & Tweaking 32 16-07-09 08:44 AM
Carb Help. Phaelok Bikes - Talk & Issues 9 01-07-09 02:14 PM
Carb balancers I could borrow? sam anon SV Talk, Tuning & Tweaking 3 21-11-08 06:49 AM
pipes going to carb to carb sv650nutter149 SV Talk, Tuning & Tweaking 3 07-09-08 10:16 PM
