Hi all im looking for some carb balancing gauges as i think my carbs could do with balancing, i cant afford a new expensive set so i would like to see if anyone has a set they would part with for a small sum?
Cheers Ben |
you can make them, beabert on hear made some, i will be doing the same at some point as well
Large Member
What do you mean by expensive?
Mine cost me £40 and seem to work alright. Can't remember where I got mine from but these are the same ones and the same price. http://cgi.ebay.co.uk/BIKE-IT-CARB-B...31f451ff3438c3
How to amuze an idiot: Look right-> <-Look Left |
well i need them fairly soon as it feels like the backs not running right through part of the rev range and a bit clunky on idle.
the two dial version i can pick up for £15 posted |
Large Member
But if you get the four dial version you are future proofed
any body got any, or reccomend a half decent set ?
![]() Last edited by beabert; 20-02-11 at 01:52 AM. |
what dia pipe did you use an what liquid?
im guessing it works by vac pressure pushing both ways along the tube an moving the liquid in between? |
#9 | |
Sucking both ways yep. You just want the level on each side not to change over time. When you first turn it on, one will go up the other down, so kink the cable to stop it being drawn all into the one side until your ready to adjust. Then adjust the balancing screw bit by bit to get fluid movement as close to nil as possible. That video is of mine completed. balanced. The level of the fluid doesn't have to be exact(as long as each side is roughly the same height) but you want no movement from one side to the other. Read the manual regarding procedure. Warm engine and what rpm it needs to be set to etc. If you do make one, my tip is insert the correct amount of oil in one go, if you add oil a second time then one you introduce an air lock and its tricky to get them out! I used a large syringe the first time and it was easy. Im sure a tunnel would be adequate. Good pic of one here. ![]() Last edited by beabert; 20-02-11 at 03:28 AM. |
#10 |
sweet cheers dude, does there have to be a certain amount of oil/water?
water with couloring seems a good idea ![]() cheers Ben |
Wanted: Clocks for carb model naked + headlight and carb. | Gazdaman | Stuff Wanted | 2 | 17-03-10 03:50 PM |
Carb balancers and air boxes | drag | SV Talk, Tuning & Tweaking | 32 | 16-07-09 08:44 AM |
Carb Help. | Phaelok | Bikes - Talk & Issues | 9 | 01-07-09 02:14 PM |
Carb balancers I could borrow? | sam anon | SV Talk, Tuning & Tweaking | 3 | 21-11-08 06:49 AM |
pipes going to carb to carb | sv650nutter149 | SV Talk, Tuning & Tweaking | 3 | 07-09-08 10:16 PM |
