#11 |
Is this more likely to happen on an off-road bike? I'm not Marc Coma or Cyril Despres (in fact I'd propbably struggle in an amateur enduro event
![]() Last edited by -Ralph-; 03-04-11 at 10:03 AM. |
#12 |
Your forks etc are obviously gonna take more of a pounding but cope with that pounding better than a road bike.
Just a case of poor tyre fitting that's all IMO. |
#13 | |
The examples quoted here aren't caused by torquing a fastener up slightly out of the manufacturers spec, it's caused idiots either not tightening a fastener at all, or hugely over tightening it. It's perfectly possible to torque most standard fasteners close enough to the required value without using a torque wrench if you have a reasonable level of skill and experience. If you don't then I agree a torque wrench should be used, and it should always be used on really critical fasteners e.g. head bolts. |
#14 |
I sorry I disagree yet again,crushed speedo drive on a front spindle probably cause by overtightening,secondly front spindle comming undone due to undertightening.
Both scenarios where +/- 5lbs could be enought to cause this. Industry standard would be about 45lbs so 40-50lbs by guestimate on a large nut or bolt head like a spindle is not a lot of pressure and for the DIY mechanic using a fair sized socket wrench or spanner very hard to get within the peramiters,especially if it has corrosion or burred threads. We are all entitled to our own opinions |
#15 | |
Maybe if I owned a smaller torque wrench of similar length to the ratchets in my socket set and smaller range, I would perhaps learn what a certain torque value feels like over time, but I don't, my torque wrench is about 450mm long and has an operating range of 28 to 210nm. Most nuts need very little effort when you use something that long, especially if it only needs 30nm, and you don't learn how much pressure you would need to apply with a normal ratchet. I wanted a wrench that size for the rear wheel spindle and for the wheel nuts on the car. Maybe a smaller wrench with an operating range up to 60 or 80mn for those kind of bolts can be on my birthday list. |
#16 | |
Knob faced knobster
2011 Speed Triple 1050 Last edited by dirtydog; 03-04-11 at 07:13 PM. |
#17 | ||
I've had bikes for the last 30+ years and I have not ever had a bolt loosen or snapped a bolt due to over or under tightening. Perhaps I am simply "lucky", but the evidence tends to suggest that experience and a good level of mechanical sympathy is vastly superior to the blind following of torque figures. |
#18 | |
#19 |
Mikerj,If you have never had a bolt strip or break in 30+ years of fitting you are a better man than me.I have spent 40+ years working on all sorts of engines and know that corrosion,heat or stretching can make a bolt susceptible to breaking and steel bolts into aluminium are the worst when you do not know what has been done previously.
Yes,I will fit something and do it up without a torque wrench and be pretty near the setting but for the sake of checking it I was taught to err on the side of caution and do a torque check-----a spindle is a single nut so about 10 seconds. Why do tyre fitters torque check wheel nuts as does a good mechanic on a service.They were probably all tight when initially put on but can slacken off Reason for the disclaimer when you have new tyres fitted. The number of clutches,bearing caps or heads I have seen knackered due to not being pulled down or fitted properly beggars belief. There is a lot of difference between somebody who does it for a living and somebody who does it as a DIY mechanic and if they don't have the professional skills they are less likely to damage something if they are doing it by the book and use the torque settings.Most of the people on here have a limited mechanical aptitude and it is they that I am trying to help not teach a time served mechanic how to do his job It maybe better if I keep my advice to myself in future and just let people get on with it in their own ways,in the end dilligaf. Last edited by Dicky Ticker; 04-04-11 at 09:09 AM. |
#20 |
DT knows my pedigree as I know his. I respect his view and mostly agree.
I hope I still retain a sympathy with fasteners. I always use a torque wrench where appropriate. However, I do not use it blindly. I combine it with feel, if I am not happy with the feel of a fastener before it has reach the appropriate torque, I back it off and investigate why. I would rather throw a nut/bolt in the bin than risk it stripping or fracturing. The problem with tightening used fasteners is you never know what the previous spanner wielder has done. You would hope that when tightened the fastener was still within the elastic region of a stress/strain relationship as once beyond the yield point deformation is permanent. Secondly, there is an issue with lubricated threads, the derived clamping force will be higher with a lubricated thread at a set torque and you could end up with deformation of whatever you were bolting up.
Not Grumpy, opinionated. |
triumph 599/595 disk bolts torque | barwel1992 | Bikes - Talk & Issues | 9 | 15-05-10 12:42 PM |
Torque link bolts | gerrymcghee | SV Talk, Tuning & Tweaking | 9 | 30-12-09 12:13 PM |
How important is it to Torque Bolts? | Son of a beesting | SV Talk, Tuning & Tweaking | 28 | 21-10-09 02:42 PM |
Bolts for Curvy Torque Arm. | petevtwin650 | Stuff Wanted | 5 | 21-01-08 09:06 AM |
Specified torque for bolts etc...? | KayDee | SV Talk, Tuning & Tweaking | 2 | 05-03-06 02:07 PM |
