28-05-18, 08:35 PM | #1231 |
John T
Re: What have you tinkered with today?
28-05-18, 09:45 PM | #1232 |
I spent a few minutes with an eBay 32mm deep socket and my grinder and Dremel and made a socket for the steering stem nuts:
https://imgur.com/a/XLf16Ta Last edited by proze; 28-05-18 at 09:50 PM. |
29-05-18, 08:44 PM | #1233 |
Not motorcycle related
Removed OEM car stereo from new car, took my stereo out of my car that's going. Put my stereo in my new car, put OEM stereo in my old car. Clear? Taxed and insured my new car.
29-05-18, 08:52 PM | #1234 |
Took the old chain and sprockets of the Van Van ready for a new set which should arrive tomorrow.
used to be littleoldman but forgot password due to failing memory |
30-05-18, 10:19 PM | #1235 |
Scrubbed my brake discs with a wire brush and brake cleaner to remove corrosion on the rivets. Are they steel or aluminium on the stock discs?
31-05-18, 07:50 AM | #1236 | |
Also when I service my brakes a polish off any corrosion on the,"Float Pins" with some 500 grit paper and then polish them with Autosol Metal polish and then lube with grease(I have some of the old-school Red lithium brake grease). I do this as I got a little bit of low speed Brake-grab and having had it before on bikes I knew the cause and fix.
31-05-18, 04:44 PM | #1237 |
Cleaned my calipers for the N th effing time after riding through the winter and changed the brake fluid and bleed nipples for some s/s ones. Everything went to plan!! No sheared off bolts or endless bleeding... has my luck changed? or am I about to grab a handful of nothing and plough through a hedge? Or do I just need to cheer the hell up and accept some good fortune.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am. 05 SV650s now with proper suspension, hurrah! |
31-05-18, 04:59 PM | #1238 |
cheer up...
did you just "clean" the callipers or strip them down? |
31-05-18, 05:32 PM | #1239 |
Semi-stripped! Took out pads and cleaned pistons, seals and pins and springs in February and have washed them thoroughly with muc off every fortnight. Wheels spin freely...
31-05-18, 05:55 PM | #1240 | |
properly stripped and assembled with RRG callipers will last years before needing done again. the muppets that you see on youtube cleaning callipers by spraying brake cleaner on the seals and pistons are just that.. muppets who dont know what they are doing. |
Thread Tools | |
