13-03-19, 03:23 PM | #1501 | |
Re: What have you tinkered with today?
I agree, I use either Halfords Professional or my US Craftsman internal hexagons with a ratchet or bar. The issue here is that the threads have not moved for 13 years, even when I managed to get the first bolt moving it was tight all the way. Sent from my iPad using Tapatalk Addendum: This bike keeps fighting back! The left over bolt shaft just would not move and eventually snapped off almost flush, so I had to drill it out. It was stuck solid, it didn't move using left hand twist bits - even when I got as far as the 5mm drill. I had a M6 helicoil kit to hand so I replaced the thread. The master cylinder is all apart now, but it was a struggle. I'm still not really happy with it so I've found a good used replacement for £20 from eBay. Alan Last edited by Othen; 14-03-19 at 05:51 PM. |
15-03-19, 07:10 PM | #1502 |
Thanks for all the tips guys.
This is what they looked like after brushing on some Harpic Looks like my Arrow pipe has cracked again on the other side. I'll have to get it welded up and get a brace put in between the two pipes. The wise Bibio foresaw this happening last time it broke Then tried the coke and aluminium foil treatment which further improved them. I think they might come up good with some polish now I've still to do the cat section too |
15-03-19, 07:28 PM | #1503 | |
Gosh, you took the whole exhaust off just to clean it. We are not worthy! Sent from my iPad using Tapatalk |
15-03-19, 07:30 PM | #1504 |
Well done Darren. Looking good
used to be littleoldman but forgot password due to failing memory |
15-03-19, 07:35 PM | #1505 | |
Yeah it's getting there |
15-03-19, 08:16 PM | #1506 |
15-03-19, 08:22 PM | #1507 |
Yep it lives in the conservatory over winter. I give it a cuddle from time to time
15-03-19, 09:13 PM | #1508 |
15-03-19, 11:05 PM | #1509 |
Ya big old softie, ya vacuumed the carpet before the photo' just for us
16-03-19, 12:31 PM | #1510 |
You can bring them up even better if you use a Brass Wire brush drill attachment but if you use this method you MUST wear overalls and safety glasses/googles.The Brass wires can come of and stick in cloths and scar the skin and the Safety Glasses/Goggles for the eyes.
Brass wire brushes can remove a lot of the final corrosion and leave a nice,"Burnished" finish or if once used and you don't like the finish the Metal polish usually works even better after the Burnishing. https://www.toolstation.com/wire-bru...xoCZjgQAvD_BwE £2.51
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 16-03-19 at 12:50 PM. |
Thread Tools | |
