#11 |
They don't look like ovals, they look like wire nails to me as they have four pyramid points and are bright steel, (ie not galv), and the one to the far right looks to be an annular ring nail, looking at their diameter I would guess that they were about 1"-1 1/2" long originally, also they were in there for a reasonable while - the heads have worn away.
You upset anyone recently?
#12 | |
My first thought when I took them out was cheap 1/2" panel pins. The bottom right one still looks like it has the original head on it. I'll take a proper look tomorrow. Last edited by keith_d; 26-06-13 at 05:55 AM. |
#13 |
I've just got the loupe out and taken a proper look.
They're definitely round, just under 1.6mm/16gauge and the longest of them are all around 12mm. Most of them have small, badly stamped ridges which I'd usually expect near the top of a panel pin. So my money's on 1/2" panel pins and as Ian pointed out, if someone spilled them they're just not worth picking up. |
#14 |
So a good reminder to check the old hoops out Regualy .
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#15 |
I ended up having to stop on the way back from the AR with a good ol' puncture so you're not the only one who ended up with a flat.
No nails in mine but a nail sized hole. J
Naked K5 - Now Red with sexy stripes!! Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock |
#16 | |
Sent from my GT-I9300 using Tapatalk 2 |
Thread Tools | |
nailed me test | Bibio | Idle Banter | 15 | 18-08-08 09:28 AM |
I got nailed (tyre) | Blue_SV650S | Bikes - Talk & Issues | 13 | 05-07-07 09:06 AM |
Yeehaa I nailed the U turn and passed | setanta | Bikes - Talk & Issues | 28 | 26-12-05 05:46 PM |
Tyre nailed (sob) | Jabba | SV Talk, Tuning & Tweaking | 14 | 05-08-04 07:46 PM |
