#11 | |
The speedo’s legend does seem odd, particularly as the manual says the motor makes 10 HP at 7,000RPM - I’d say 70MPH feels like near the top of that range, something like 6,000RPM. It does seem a bit odd, but that is what it says... ![]() Sent from my iPad using Tapatalk |
#12 |
Indeed - my old B100P had the same legend on the speedo. It's not wheel RPM either. Who knows?
#13 | |
Ah ha, I have it in full; I found this on a US XS650 site: Well, all Japanese motorcycle speedometers are calibrated to show 60 MPH when the cable is spinning at 2240 rpm. With a front wheel diameter of 19" the rolling distance is about 79" per revolution, or 79/12 = 6.58 feet. At 60 MPH or 1 Mile Per Minute the wheel will rotate 5280/6.58 = 802 RPM. So, you would need a speedometer drive with a 2240/802 = 1:2.79 ratio which is pretty close to your 1:2.75 ... so, it is nothing to do with engine speed, it is the speedometer drive calibration. One learns something new every day (well, not Tuesdays). Sent from my iPad using Tapatalk |
#14 | |
This makes more sense: my Bloop has a 2.75”x17” rear tyre, so its circumference is 71”. 60MPH is a mile per minute, so the rear wheel will rotate: (1760*3*12)/71 = 892 times in a minute. The gear ratios on the Bloop are (in top gear): (3.125*1.1*2.214)=7.61 overall. So, for every 892 rotations of the rear wheel the crankshaft rotates 892*7.61=6788 times. 6788 RPM at 60 MPH makes sense (maximum power is quoted as 10 HP at 7000 RPM)... so I’m really impressed with the Bloop reaching an indicated 70MPH yesterday (admittedly down a slight slope and after a 2 mile run up), particularly with my 6’2” 210 lb frame attached to it (and not wearing Speedos whilst impersonating Rollie Free). ![]() PS. I cleaned the baffle according to the article Craig380 provided a week or so ago, it only took about 10 minutes with a wire brush and a propane torch to get it looking okay - maybe that accounts for the improved top speed? Sent from my iPad using Tapatalk Last edited by Othen; 23-06-19 at 02:00 PM. |
#15 |
Aha, speedo mystery solved! And yes, clearing the baffle does help. The most important bit to clear is the internal diameter of the baffle, when that's as clear as possible it will run as Mr Suzuki intended ...
#16 | |
... that article was quite helpful - the bit about adjusting the ignition timing is much better than both the Suzuki and Haynes manuals. I took the Bloop out for another needless errand today, a trip around town wearing shorts, tee shirt and an open face Nolan helmet... I was 17 again. Sent from my iPad using Tapatalk |
#17 | |
![]() I never had a flywheel puller when I had my B100P so had to resort to doing it all through the flywheel slots ![]() |
#18 | |
Eeeek! Now that would be a hard job. It is a real faff even with a puller: adjust the timing ‘a bit’ - put the flywheel back on, adjust the points through the little slot and see if it is right, if not pull it all apart and try again. We have all been spoiled by electronic ignition and forget this was the norm 40 years ago. Sent from my iPad using Tapatalk Last edited by Othen; 25-06-19 at 11:53 AM. |
Thread Tools | |
Best buy in my life | Joe Marcon | Idle Banter | 18 | 31-07-12 04:06 PM |
After Life | Speedy Claire | Idle Banter | 8 | 09-12-10 05:16 PM |
Life | plowsie | Idle Banter | 53 | 09-09-09 06:30 PM |
Five Life now | Shellywoozle | Idle Banter | 11 | 10-06-08 10:08 PM |
I am about to get a second life | Blue_SV650S | Idle Banter | 2 | 12-10-07 07:02 PM |
