16-01-20, 08:07 AM | #11 |
Re: Putting standard can back on
As I expected the joint leaks quite a lot as the standard can has a lot of back pressure so Ive ordered some thin gasket paper which I hope will seal under the clamp....
16-01-20, 10:31 AM | #12 | |
https://www.ebay.co.uk/sch/i.html?_f...+tape&_sacat=0
16-01-20, 11:06 AM | #13 |
thanks, yes that might do the trick as it says its good for 120ºc....
16-01-20, 11:08 AM | #14 |
It does the job. Smells for a short time when it first heats up but works
16-01-20, 08:45 PM | #15 |
Just thought I would mention. If you use this tape treat it with respect as the edges are sharp and even more so when off the roll and it's easy to cut yourself :O
20-01-20, 06:38 PM | #16 | |
This shouldn't be an issue, unless... ...someone has butchered the job of cutting the original can off. The gap should be no wider than a hacksaw blade and the reconnection sleeves seal fine in this case. |
22-01-20, 10:41 PM | #17 |
I threw away the original can I chopped off and have had to buy another second hand which of course wasnt cut in exactly the same place. The gasket paper seems to have done a good job but it still needs testing.....
Thread Tools | |
Considering putting stock muffler back on :-s | Tommiller0211 | SV Talk, Tuning & Tweaking | 37 | 02-11-19 11:18 AM |
Putting a CAT C back on the road? | LewSpeight | Bikes - Talk & Issues | 11 | 29-01-15 07:33 PM |
putting her back together | Wideboy | Photos | 20 | 21-03-09 10:00 PM |
putting standard can back on? | hovis | SV Talk, Tuning & Tweaking | 5 | 02-08-07 08:03 PM |
Putting original can back on... | sprocket | SV Talk, Tuning & Tweaking | 5 | 23-03-05 08:19 PM |
