#11 | |
The Sick Man
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#12 | ||
'81 Honda H100A '18 Honda MSX125 (Grom) |
#13 |
Silly question but your actual filenames... do they end in .htm or .html? It's an easy thing to miss if you haven't already made sure.
You can test your framset by setting the frame links to other pages outside your site (i.e. set them to http://forums.sv650.org/ - as long as there's no framebusting code) Good luck ![]() Edit: I just tested the frameset code in TSM's post and it works with all the links to here so I reckon you've got files with .htm extensions instead of .html. |
#14 |
Originally I had them with .htm extensions but then changed them to .html thinking that was the problem. Do frames rely on html extensions then? I will double check all this later - thanks
#15 | |
#16 | ||
![]() Btw, I also took out the / in all the links i.e. src="banner.html" |
#17 | |||
#18 | |||
Unfortunately, "features" like Windows XP hiding file extensions has meant that most people don't realise that an extension is still a full part of the filename and is nothing special. |
#19 | |
Errrr. Not quite, the extension tells the web server what to do with the file. You don't write the mime encoding stuff into a HTML file but when the web server presents it ,there are encoding headers dictated by the file type. Similarly a file does not need to be html content, it could be php, perl or an application. The server must know what to do with it and this is dictated either by the file extension, presence in a cgi directory etc.
Not Grumpy, opinionated. |
#20 | ||||
Thread Tools | |
Wicked new lid design | thor | Bikes - Talk & Issues | 4 | 06-02-09 03:06 PM |
Dream SV design | zunkus | Bikes - Talk & Issues | 51 | 26-04-08 04:48 PM |
Design me a website Banner | 600+ | Idle Banter | 6 | 05-03-08 07:14 PM |
Simple Website Design | sharriso74 | Idle Banter | 22 | 31-03-06 10:30 PM |
Website design, domain buying etc... | Daimo | Idle Banter | 11 | 19-01-06 12:40 PM |
