#2591 |
if its titanium bolts please use some form of coating on the threads as they tend to weld themselves onto anything.
#2592 | |
Stainless steel threads also like 'galling' ( welding themselves into the hole ) https://www.essentracomponents.com/e...ss-steel-bolts .
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 06-02-22 at 04:09 PM. |
#2593 | |
#2594 | |
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
#2595 | |
Molybdenum disulphide ( Moly ) is a good one, so molycote, molygrease etc, moly is a fantastic high strength lubricant. I add 2% Liqui-moly to engine oil in bikes with wet clutches ( which is OK according to Liqui-moly instructions ). Copper grease more an anti-corrosion than a lubricant. https://www.westfieldfasteners.co.uk...d_Galling.html
#2596 |
do not use a lubricant or copper grease. they are disc bolts so need a thread lock designed for de mounting bolts. Loctite 2259681 Lock ‘n’ Seal is a good one. i personally use a loctite blue stick.
#2597 | |
I use a loctite 248 9G blue stick, easy to apply and lasts ages in toolbox and will not spill... One thing is that stainless bolts are not proper hi-tensile because putting carbon into stainless steel is a no-no... https://www.boat-renovation.com/high...s-steel-bolts/
#2598 | |
#2599 |
under normal circumstances yes but we are talking disc bolts and any for of lube is a risk of them coming loose. also people tend to use waaaayyyy tooooo much copper grease on things.
#2600 | |
But it would seem the only advantage of stainless steel bolts is the exposed heads should not rust (unless it is a s/s bolt and s/s nut situation ) I know from experience we used to isolate stainless steel fixings from mild steel, as in a framework, by placing neoprene washers between the s/s washers on the fixings and the mild steel to avoid corrosion (dissimilar metals ! ) |
Thread Tools | |
