12-03-17, 08:21 PM | #2981 |
Re: Vintage film cameras
They do look old don't they? The negs are so much sharper but tiny! Maybe a filter would help? I was reading older posts, did you sort the light leaks on the XD 5?
12-03-17, 08:41 PM | #2982 |
I went to WYC and another Camera shop to ask advice on the seals. Neither of the repairers could see a problem. It's not coming through the shutter. I replaced the hinge seal with a longer, wider one and I'll try it again.
The only other think I can think of is if there's a seal under the top plate somewhere, around the shutter button or wind cranks. Service manual doesn't show anything though. |
12-03-17, 09:00 PM | #2983 |
Strange that one, hope you get it sorted. The Paterson 3 tank worked well, I have another loaded 16mm cart with the Minolta 16ii so will shoot that at some point. Need to get the 127 films shot at some point.
13-03-17, 08:15 PM | #2984 |
Had a Dacora arrive today but the lens was no good. Took it off and fitted the Ennagon f3.5 in place of the Subita f4.5. Still 75mm. Worth a go.
13-03-17, 08:43 PM | #2985 |
Regula(r) Dr. Frankenstein aren't you! Not been up to much but getting a little time to get through the many things that ave backed up at home. I also find myself trawling ebay for cameras I don't need. Maybe it's the frustration of not having time to fiddle with the ones I've got! There is a cheap Certo 6 though, needs a replacement shutter blade (Synchro Compur) and maybe bellows, and a few Mamiya Sixes though none terribly cheap.
13-03-17, 09:12 PM | #2986 |
I'm the same. I really don't need more but cannot help myself! Maybe that is why others don't come in here. We are a bad influence on them!
14-03-17, 08:47 AM | #2987 |
14-03-17, 08:24 PM | #2988 |
Hey Yoko, York is only 53 mins from you. Its four hours from me!
14-03-17, 09:13 PM | #2989 |
I know it's quite a way from you. Only half an hour from me though. I usually go there if I need serious shopping. There's not much in Northallerton
14-03-17, 09:15 PM | #2990 |
Will have to sort something out at some point.
Thread Tools | |
