Old 20-04-11, 06:17 PM   #21
Default Re: Ground anchor installation
If you can manage to get approx 12 inch x 12 inch x 12 inch cube of decent concrete in the ground, that is not gonna come out easy I guarantee that.
I've had to kango fence posts with less concrete out even though the post is a good lever because it wouldn't budge.
You won't have a problem as long as the potential thieves don't turn up with a digger
Rapid hardening or rapid setting cement is used in the same quantities as regular btw.
Old 20-04-11, 07:22 PM   #22
Ruffy
Ruffy's Avatar
Originally Posted by keith_d View Post
IF you don't want to lift a lot of paving consider driving 2' lengths of rebar at 45 degrees through each side of the hole into the subsoil before you pour your concrete. There's hardly any oxygen 2' down so they'll last for decades and make it almost impossible to lift your block.
When fitting a Y anchor type thing then try get some lengths of rebar rod and bash them into the ground around it.
If you're going to consider this, be very careful that there are no underground services under the area you are driving into. It wouldn't be pretty if you hit an electric cable, gas or water pipe.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 20-04-11, 09:10 PM   #23
I've hit all 3 at various times and wouldn't recommend it
Old 21-04-11, 07:19 AM   #24
flymo
flymo's Avatar
get yourself a bag of Postcrete from B&Q. Its amazing stuff and sets solid within 10 minutes.
Once you have the hole ready, you pour the powder mix in and then add water. Make a cuppa, bobs your uncle.
Old 21-04-11, 01:48 PM   #25
Quiff Wichard's Avatar
postcrete wudda been my idea too.. maybe "aquire" some gravel from around about when out walking..and lob it in the dry mix..and mix up follow instructions on the bag .. about £5 a bag I think
Old 21-04-11, 04:01 PM   #26
Stenno
What specialone and flymo said. Although as someone else said you might struggle to lift bricks in the middle so you might have to start at the edge and snake your way in.
Old 06-05-11, 11:29 AM   #27
hindle8907
hindle8907's Avatar
cheers for all the info guys think I might have a go this weekend. will let you know how it goes.
Old 07-05-11, 01:57 PM   #28
Reeder
No problem mate. Hope I helped.
Old 07-05-11, 04:39 PM   #29
MisterTommyH
MisterTommyH's Avatar
1 bag of 20mm pea gravel, 1 bag river sand, 2 decent shovels of cement. Ish. Be right.
That works using extra rapid cement but it's not the cheapest. Not sure whether you'd use more or less cement with normal cement.
Pea gravel isn't really the best to use in concrete. You want something a bit more angular to get enough aggregate interlock.
MisterTommyH is offline   Reply With Quote
Old 07-05-11, 04:48 PM   #30
He's holding a ground anchor in not the tyne bridge lol. Might be better to say something he could ask for in merchants, I would guess you'd get some funny looks asking for "peas possible a bit more angular and interlocking please"
Y-Anchor ground anchor - For Sale SVStorm For Sale - Other Bikes and General biking items 2 14-10-10 09:24 PM
Ground anchor? SUPERSTARDJ01 Bikes - Talk & Issues 9 12-11-09 05:38 PM
ground anchor installation hindle8907 Bikes - Talk & Issues 43 28-05-09 09:21 AM
Ground Anchor help mustnt grumble SV Talk, Tuning & Tweaking 12 03-10-08 09:31 PM
What do you think of my new ground anchor? thor Photos 12 11-05-07 04:31 PM
