#21 |
did you buy the brembo mc off ebay by chance?
#22 |
#23 |
i'm beginning to think that you have a dud MC, might not be a knockoff but it could be faulty. even if the MC has the wrong ratio it would still give a firm lever.
stick the SV one back on and see if you have joy with that. top tip. you dont need to bleed the whole system when fitting the SV MC back on. disconnect the banjo, remove old MC, put new MC on then connect banjo. DO NOT PULL THE LEVER. top the rez up and then quickly 'flick' the end of the lever using around 5-10mm of the lever travel with a finger rapidly for about 5min. this will dispel any air in the MC back up to the rez. do not use full lever travel till the 5 min are up. |
#24 |
Next thing to check is that the bleed valves on the calipers are in good condition. They more or less rot over time and the threads don't hold it tight any longer. A good give away is a firm press on the top of it and see if any fluid leaks out.
Mind posting a couple of pics of your Brembo MC? I'd be surprised if it's a fake tbh
93 VFR750 - WAY too many mods to list. Crashed ![]() 04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC |
#25 | |
#26 | |
#27 |
Looks legit enough. The packaging should have a serial number you could check with Brembo
I'm assuming you bought the right angle banjo eyelets to go under the MC?
#28 |
Yes its got a serial number and a brembo card which i might check and if the banjo eyelet is whats on the brake hoses then im guessing yes as when i brought the bike it came with braided hoses
#29 |
oh OK cool, seems like a VERY good price for an MCS19 and lines!
#30 |
Sorry i meant the lines were already on the bike with my original sv mc i just used them with the brembo mc
Thread Tools | |
Iv only gone and bloody done it!!!! | Tommo1988 | SV Ecosse | 21 | 19-04-13 12:47 PM |
Bloody TT, bloody MOT, cocked it up again | timwilky | Idle Banter | 9 | 03-06-11 09:06 PM |
bloody PCs | timwilky | Idle Banter | 9 | 22-08-08 11:43 AM |
Bloody M6 | timwilky | Idle Banter | 17 | 25-01-08 04:02 PM |
HOW DO YOU BLEED THESE BLOODY BRAKES | bobbydee | SV Talk, Tuning & Tweaking | 4 | 18-07-05 09:22 AM |
