#341 |
I think I might have stuck a standard connector plug on to it, because I started to replace all the bullets with that type. Tam would have to check though
#342 |
cheers Daz
#343 |
Was nice & easy on the gixxer, some muppet had wired in the R&G no. plate light with one of those household screw in type double connector blocks. Just soldered the feed wires and attatched the ign live feed in at the same time.
![]() Might need another gizmo soon bib's, so get making a universal one with just a long ign live feed wire and no connector, then I can just source a bike specific one, when required.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground" The Stoppy King
![]() Last edited by SIII; 21-01-15 at 06:44 PM. |
#344 |
yup muppet is the word. i hate those things with a vengeance as they always end up a green furry mess. they are ok for household wiring but have no place on a bike.
#345 | |
![]() Good point though - that switched live you had it connected to would be the ideal solution for Bib's gizmo. |
#346 |
Yeah I don't know what went wrong with it. It was really handy when it worked
#347 | |
![]() I think this is the connector, so looks the same as the pointy. http://www.ebay.co.uk/itm/2005-SUZUK...-/110880101791 |
#348 |
if it is then its plug and play just like the SV
#349 |
#350 |
Gizmo is now Mk4 which is fully universal to fit any motorcycle apart from those that have cambus e.g. newer BMW.
the Gizmo will be fully removable once installed but will leave an indication that there was something there. those that can use the rear brake light switch will still be able to remove leaving no trace that it was ever fitted. so once you buy a Gizmo it can be transferred to almost any motorcycle on the market. |
Thread Tools | |
Jetpack like gizmo for flying over water.... | MotorPsych | Idle Banter | 1 | 28-11-11 06:36 AM |
gizmo freaks.....you got to see this. | rictus01 | Soho Massive | 16 | 16-02-09 04:53 PM |
Nifty little gizmo | riktherider | Bikes - Talk & Issues | 13 | 14-10-08 09:41 AM |
What's the gizmo | Ed | Bikes - Talk & Issues | 3 | 13-07-08 10:58 PM |
SOLD..... G Pack Gizmo... | reggie perrin | For Sale - SV's and SV related items | 1 | 16-01-06 04:52 PM |
