Track Days Post up here about trackdays
Old 06-08-11, 11:04 PM   #31
hardhat_harry
Default Re: Taken out at Cadwell :-(
Diamond Rearsets bend very easily when crashed.
Race Supplies are good robust ones and he supplies spares
http://www.ebay.co.uk/itm/Suzuki-SV6...item5ae16d2686
Loads of club racers use them and they are skint most of the time so they have to be good value.
Old 06-08-11, 11:58 PM   #32
lukemillar
Originally Posted by fastdruid View Post
Heh, first time with the camera mounted there and it didn't work quite as well as I'd hoped. I think for next time I'll drill a suitable hole in the centre of the nose cone[1] and make a proper stabilised mount for it.
This is how I have mine mounted to my racebike. I used a goggle mount, drilled and screwed through the underside of the nose and then poked the lens through a hole in the fairing. I find that I get very little in the way of bug splatter or rubber stuck to it as well. The only anti-vibration thing is a bit of 2-3mm foam stuck between the mount the fairing, but I find the picture is incredibly solid.
#24 - Honda VFR400R NC30
lukemillar is offline   Reply With Quote
Old 07-08-11, 07:56 AM   #33
muzikill
muzikill's Avatar
Look almost exactly like my damage from the other week, and jeez! - even with bungs the fairings and tank still got it bad!
scummy sh!te, maybe part of the track day rules should be if you become involved in a incident you HAVE to stick around for the de-brief. this would actually put the wrong people off and cause less incidents.
What if you had been seriously injured?
Old 07-08-11, 08:08 AM   #34
fastdruid
fastdruid's Avatar
Yes, I'm not too happy with the R&G bungs, didn't exactly do a lot before snapping. The second set worked better but they're kind of level with the fairing so it took quite a hit before they even touched.
Druid
Old 07-08-11, 08:39 AM   #35
That sucks dude, not sure what happened just before he hit you but if that was a 'gap' he was going for, he's a d1ck.
I've no doubt if he carries on TD's, karma will repay him for not coming to see you after.
Heal soon dude
Old 07-08-11, 12:50 PM   #36
hindle8907
hindle8907's Avatar
What a tw4t glad your ok-(ish) dude !!!
That is unbelievable he didn't come and say sorry !!!
Old 07-08-11, 02:22 PM   #37
Binky
Emily Howard rides an SV
Binky's Avatar
Just watching your videos FD. What kind of speeds are you getting at the ends of the two straights out of curiosity? Would like to know how much faster yours is than a standard SV.
Wowee Zowee
Old 07-08-11, 03:17 PM   #38
fastdruid
fastdruid's Avatar
Datalogger says 128, which although the accuracy depends on how well I measured the circumference, its geared for around 129 at 10.5k and the shift light (set to 10k) is firmly on so it can't be far out!
Druid
Old 07-08-11, 03:54 PM   #39
Dave20046
Dave20046's Avatar
That's ****
properly my worst fear on the track, takes a lot of concentration to stop myself from doing shoulder checks....will take even more after watching that!
Can't the organizers pass on his details?
Old 07-08-11, 04:13 PM   #40
fastdruid
fastdruid's Avatar
The internet is my friend and has located him. Personal details now removed however.
Druid
Last edited by fastdruid; 08-08-11 at 03:08 PM. Reason: Removal of personal details
so who was best at Cadwell then Quiff Wichard Soho Massive 25 08-10-09 07:30 PM
See you at Cadwell? Keith1983 Photos 1 25-08-07 02:34 PM
Cadwell - 04/05/07 andyaikido Track Days 3 03-05-07 05:39 PM
Cadwell Oct 06 Tim in Belgium Photos 0 05-01-07 09:57 PM
Cadwell - 28/09/06 andyaikido Bikes - Talk & Issues 3 26-09-06 04:26 PM
