17-05-17, 11:45 AM | #31 | |
Re: 2009 fast idle
tickover is 1300rpm. That's about 22Hz which is right at the lower edge of the range these things are designed to detect. Four stroke cycle fires every 2nd rev. So that's now 11Hz for a single cylinder. Uneven firing intervals of a vtwin - so you've got 2 11Hz frequencies overlaid on each other which doesn't make 22Hz cos they're unevenly spaced. Engine noise - huge bunch of other stuff going on, which are all bang bang or tap tap, rather than a nice smooth sine wave.
Silver SV650SK3, Fuel exhaust |
17-05-17, 01:25 PM | #32 |
Re: 2009 fast idle
Did you check the throttle cables? Try slacking both off to make sure there's not something holding the throttle open a little.
17-05-17, 02:56 PM | #33 |
Re: 2009 fast idle
I think this might be the problem. https://www.youtube.com/watch?v=NwxZga25YfY I need to find out how to adjust the needled correct.
17-05-17, 06:05 PM | #34 | |
Re: 2009 fast idle
so let us get this right, you have removed the tacho needle some time ago and now your bike is revving higher? |
17-05-17, 07:35 PM | #35 |
Re: 2009 fast idle
So how do you know it's ticking over at 2000rpn?
17-05-17, 09:55 PM | #36 |
Re: 2009 fast idle
Well..this is the problem. I`ve been into this "problem" for some time and I might have forgoten to mention some facts. When I bought the bike...the first thing I did was strip most of it. Fix some plastics and other bits and pieces, and changed the led lights on the speedometer. And to be honest..before I open the speedometer, I didn`t even pay attention to the idle. So here is a short clip from my last trip. Maybe you can hear it idling and tell me if it`s all in my head. https://www.youtube.com/watch?v=hRoq...ature=youtu.be
17-05-17, 10:13 PM | #37 | |
Re: 2009 fast idle
I use Firefox browser.Open two tabs,one with your vid and one with this, https://www.youtube.com/watch?v=Jwscv0tHvzM run them side-by-side.Sound pretty close to me so it's not the engine.As per previous post you may have to go back to the clock and move the needle.PITA but..... My 10 Penn'th/2 cents.
17-05-17, 10:37 PM | #38 |
Re: 2009 fast idle
I actually did that like 1 hour ago...sound pretty close to me too.
I guess the needle was the problem all the time..and I spent 1 week in the garage checking all the sensors and studying the manual. At least I learned more about the bike than I already knew Now I just need to find some good guide how to position the needle to be precise and everything will be great. |
17-05-17, 10:41 PM | #39 | ||
Re: 2009 fast idle
"All the technology in the World cannot defeat a bent penny in a toilet pay-slot"
17-05-17, 10:53 PM | #40 |
Re: 2009 fast idle
I`ll just leave it as it is for now, and try to fix it the next time I have the need to remove the front fairing. There is no need to remove the plastics AGAIN for this.
Thread Tools | |
Fast idle issue | tom_e | SV Talk, Tuning & Tweaking | 12 | 18-07-16 10:42 AM |
FI fast idle problem. | salchichas | SV Talk, Tuning & Tweaking | 7 | 20-02-12 10:33 PM |
Fast idle not working | SVMAT | SV Talk, Tuning & Tweaking | 2 | 06-05-10 05:23 PM |
Car Idle speed suddenly very fast | JediGoat | Idle Banter | 16 | 20-11-09 11:41 PM |
Need Help (fast idle) | Decken | SV Talk, Tuning & Tweaking | 5 | 20-03-07 12:26 PM |
