Old 10-08-18, 02:55 PM   #6161
Default Re: Gripe of the day - What is yours?
ROFL. so you spend all that money on waterproof luggage but fail to spend £30 on a set of overproofs then go on holiday... you deserve all you get
Originally Posted by Craigg View Post
numpty!
I chose that day because the weatherman said it was clear blue skies everywhere. I always believe everything he says always
Old 10-08-18, 03:21 PM   #6162
shiftin_gear98
shiftin_gear98's Avatar
OK so started with the screw driver. Relay looks perfect no corrosion. Well the screws are slightly burnt now! Time to take switch apart.
Edit
Everything looks OK? What do you guys suggest. It does the following.
Key in, ignition on, pump primes, push button no click no sound no nothing. Relay looks perfect so too does the switch.
What should I try replacing first?
Old 10-08-18, 04:06 PM   #6163
Kenzie
Kenzie's Avatar
Moving house.
Sent from my Xperia using Tapatalk
Old 10-08-18, 04:13 PM   #6164
admin
John T
admin's Avatar
Edit
Could be one of the safety switches such as the one on the clutch or side stand.
Sent from my Nexus 7 using Tapatalk
Old 10-08-18, 04:17 PM   #6165
ophic
ophic's Avatar
the lunatics have taken over the asylum. we have had to get care workers in to do duties for my wife as im not capable or allowed due to my ill health.
i was informed that there are different care workers to do different tasks even though most care workers have been trained to do all the tasks. so you get 1 person to dispense drugs another to use "equipment" and another for personal stuff like getting dressed etc.etc. so for my wife to have a bath it requires a nurse trained in using a mechanical lift (bath chair) to lower my wife into the bath then another nurse to wash my wife then the other nurse has to work the chair again then the other nurse has to dry and dress. so thats two wages to do one job, or two people that could be dealing with different clients.
now for the best part. none of the nurses are allowed to lift my wife's foot/leg on and off the stair lift.
WTF is going on with society.
Let's back it up a bit and think. The simple and sensible idea, based on industrialization concepts, is that no-one performs tasks that they haven't been trained for and assessed as capable. Makes perfect sense.
So you'd think that they'd simply train the right people to do the jobs they need to. This is where it falls down. The concept isn't flawed - just the way "we" do it. We're either so stretched for staff that they can't take time off for additional training, or the whole thing has just got bogged down in administrative overhead. Or - probably the most likely, is that no-one at the right level of decision making has any interest in making one person capable of doing the jobs of three. Lastly, if you even achieve that goal, you might well just end up with more unemployment overall.
I mean everyone needs feeding regardless of whether they work or not. Therefore industrial efficiency in the workplace has limited returns.
Silver SV650SK3, Fuel exhaust
Old 10-08-18, 05:11 PM   #6166
shiftin_gear98
Admin, I love you. I had tried cleaning the clutch switch contacts. But it still didn't work. So I just tried ramming a bit of wire in the contacts to bypass the clutch lever and..... She's alive!
A new clutch cable was on my shopping list as I have stupid amounts of play. Looks like I get that have a fiddle and see.
Once again big up the the OMO. Thanks.
Where's a beer...
Old 10-08-18, 05:48 PM   #6167
admin
John T
admin's Avatar
Where's a beer...
Great news. It's always worth checking the simple things first. I'm not sure if the clutch switch is a common problem but I'm sure this happened to more than one person on this forum.
Old 10-08-18, 06:05 PM   #6168
dirtydog
Knob faced knobster
dirtydog's Avatar
I've had a few clutch lever switches fail in the 15 years I've been on SVs. Current sv the switch failed so I bypassed it years ago
2001 SV650 in shimmerin green, Not broken anymore
Old 10-08-18, 06:23 PM   #6169
admin
John T
admin's Avatar
Strange isn't it. I had two SV's for 15 years and never had a problem. The only time i had to bypass the switch was when i dropped the bike and broke the clutch lever.
Sent from my XT1032 using Tapatalk
Old 10-08-18, 06:42 PM   #6170
dirtydog
Knob faced knobster
dirtydog's Avatar
I had clutch switch fail on my first sv, then my third sv thevswitch has failed and been bypassed before I bought it and current sv has had 2 switches fail and has been bypassed for at least 8 years
Sent from my iPad using Tapatalk
whats ur biggest gripe about the uk? kwak zzr Idle Banter 101 15-11-16 06:33 PM
heated grips gripe adw Bikes - Talk & Issues 8 12-05-10 02:48 PM
