#681 | |
#682 |
Decided to reskin the Samurai Trip 35 as I don't like the way the vinyl feels. I have ordered some blue leather for it. Have a replacement 50mm lens coming for the Yashica FX-D, may pull the fungus one apart at some point and attempt a clean. Have you shot with the Trip yet Yoko?
#683 | |
#684 |
Its a zone focus so you will need to estimate distance or use the handy symbols on the lens barrel. Don't forget to set the iso on the barrel as well.
Can anyone recommend any good photography biographies? Read Don Mccullin Unreasonable behavior and I have Ansel Adams In Focus.
Flickr https://www.flickr.com/photos/39887875@N06/ Last edited by Kenzie; 09-05-16 at 08:09 PM. |
#685 |
Yoko your flash looks to be a manual one as there is no sensor on the front to cut off the light when it is enough, so yes you'll need to use the table and set the aperture to suit the distance. Shutter speed has no effect on the level of flash light as the duration is maybe 1/10,000 second so shorter than (nearly) any shutter. If you want to fill in a backlit subject then meter the background, and figure out the aperture based on the distance from the flash. Close it down by about 2 stops, then adjust the shutter speed the other way (slower) to compensate, trying to match the metering you got for the background. Softens the flash a bit.
#686 |
#687 |
Guide number (GN, product of f-stop and distance in metres at 100ISO) of it is about 13-14 so low power but depends of course how far away you need to be, and would be fine for fill in outdoors. For indoors this is where a bit of electronics helps, to my mind. A bounce head (adjustable angle) to bring the light from above, gives a less flat photo than direct flash, plus an auto sensor to sort all that out for you. You can do manual and bounce but you then have to figure out how far away the ceiling is to find the corresponding f-stop.
#688 |
Aye, that's the flash; just a little thing. It only goes to about 6-7 metres but that's fine. I'm not planning anything special, just a few indoor shots and playing around.. It fits the Trip quite nicely. It'll be interesting to see what comes out.
I really wanted to try film at tonight's gig. The Trip shutter speed is likely to be too slow so I was going to use the Olympus autozoom as it does take some good photos. Buuuut, after finding an online manual (my instruction book is Japanese) I discovered that turning the flash mode off means a shutter speed of 1/50th kicks in and there's no manual override. Maybe I'll have to look for a cheap SLR. I'll probably take the Panasonic TZ and fire off a few shots anyway, find out what that can do at a concert. |
#689 |
Hey Yoko, I have a film tested Olympus OM10 going spare if you are interested? Wouldn't be much.
Sent from my Xperia T
#690 |
Thread Tools | |
