03-12-12, 08:40 PM | #81 |
Cant wait! Let me know when you can post!
As for the extension leads, received today thanks mate! Sent from my SV650s using Tapatalk |
04-12-12, 08:16 AM | #82 | |
Re: Accessory Distribution Gizmo Group Buy
Looks good quality and good craftsmanship, you should be proud Bibio |
04-12-12, 09:11 AM | #83 |
thanks CA. they are a right ballache to do but it's going to keep me busy
04-12-12, 09:44 AM | #84 |
One for me too! I need to wire in my satnav!
04-12-12, 12:04 PM | #85 |
04-12-12, 12:21 PM | #86 |
you can take power from the fuse box as its only live when the ignition is turned on but it's a mare to mess about with. so easier just using another point like side lights or brake switch as a trigger for the relay coil that way the only wiring your going to burn out is the new gizmo so safeguarding the main loom.
04-12-12, 12:27 PM | #87 |
01. LewSpeight
02. joshwalker094 03. bellisan 04. jandn1 05. maviczap 06. savage86 07. SV_archie99 08. Elliott 09. jchu1988 10. trudd (two of) 11. Zim 12. MJC-DEV 13. garynortheast 14. 5hort5 15. Cymraeg_Atodeg 16. Fluffer 17. SIII 18. The Guru 19. Tomor 20. Rocket 21. Nobbylad 22. muzikill 23. CodeJACK 24. 85jas 25. scotty217 26. speareig 27. Dave81 28. a_monkey_hint 29. Sally 30. Dansp 31. saucysaunders 32. Serdna |
04-12-12, 06:42 PM | #88 |
Fitting instruction pics anyone?
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
04-12-12, 06:46 PM | #89 |
Lance, Are the japanese connectors you mentioned push on spade connectors?
Suzuki SV650S K9 Kawasaki ZZR 400 Yamaha XV535 Yamaha YB100 |
04-12-12, 06:50 PM | #90 |
Thread Tools | |
Jetpack like gizmo for flying over water.... | MotorPsych | Idle Banter | 1 | 28-11-11 06:36 AM |
gizmo freaks.....you got to see this. | rictus01 | Soho Massive | 16 | 16-02-09 04:53 PM |
Nifty little gizmo | riktherider | Bikes - Talk & Issues | 13 | 14-10-08 09:41 AM |
What's the gizmo | Ed | Bikes - Talk & Issues | 3 | 13-07-08 10:58 PM |
SOLD..... G Pack Gizmo... | reggie perrin | For Sale - SV's and SV related items | 1 | 16-01-06 04:52 PM |
