Old 10-02-08, 12:30 PM   #1
maff
Default gsxr k6/7 forks
anybody know if they fit the k6 pointy?
tia
Old 10-02-08, 01:43 PM   #2
BillyC
BillyC's Avatar
Default Re: gsxr k6/7 forks
I believe the forks will fit, but you'll lose the ability to lock your stearing with the ignition - if you compare the top yoke of a K4/5 to a K6/7 you'll see that the location of the ignition changes - and that's why.
Old 10-02-08, 01:51 PM   #3
maff
ok thanks
so would a different top yolk fit the forks?
Old 10-02-08, 02:21 PM   #4
Rich
Rich's Avatar
Originally Posted by stoppy! View Post
ok thanks
The stem size is different so i'm not sure they would swap over that easily. Perhaps if you changed the top and bottom yokes and stem then it could work. Not sure though, i'm only assuming the K6/7 forks are the same size as the older ones. If they are i can't see why not.
RIP Hovis - Unlucky Boyo
Old 10-02-08, 02:30 PM   #5
maff
im tempted to get them but they come as fork legs nothing else.
so basically, if any body knows, would k6/k7 forks work with k4/5/6 everything else?
iv been reading your thread rich and am very tempted to do the swap just no idea what i exactly need. too much info on here hehe all good tho
Old 10-02-08, 02:35 PM   #6
BillyC
BillyC's Avatar
I think if they're just fork legs, then they're pretty much the same as the K4/5 units - excepting that the caliper mounts account for 320mm discs instead of the 300mm discs on the K4/5.
So you're going to have to get top and bottom yokes anyway - ideally from a K4/5. If you can't manage that, then Rictus has discussed with me, the possibility of transfering your stem from your old yokes, to the new ones - but you need to take this to someone who has the specialist pressing equipment.
For what it's worth, I have a spare top yoke from a K4/5 Gixer 600/750. Would want about ?30 for it.
Old 10-02-08, 02:42 PM   #7
The K6 forks got a couple of minor changes which make them harder to fit with older parts- one of the spindle holes is smaller which broke about 8 years of compataibility (though you can probably use hte K6 axle in some yokes) and the bottom yoke is 53mm instead of 54mm so you need a shim. It's not brain surgery mind, but the K4/K5 is simpler
(but, not available in the sexy black with the DLC fork sliders)
Old 10-02-08, 06:02 PM   #8
zadar
nope.as northy said fork K6/7 tube is 53mm at lower triple while K4/5 is 54mm.
discs are 310mm on K6/7.
there is way to keep locking option by swapping lower triple or stem/upper between them.both gen have same offset.
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
GSXR Forks tactcom7 Stuff Wanted 0 05-04-09 01:16 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
GSXR 600 K5 forks gruff SV Talk, Tuning & Tweaking 4 17-04-07 09:36 AM
gsxr forks on the sv k3? kwak zzr SV Talk, Tuning & Tweaking 12 11-12-06 11:50 AM
