22-12-08, 08:39 AM | #1 |
Valve Clearance Readings
Dear Orgers
I done my valve clearances a couple of weeks back, and here are my readings from the 15k interval check: L R Front Inlet (IN) .8/9 - .10 Exhaust (EX) .25 - .25 Rear Inlet (IN) .10 - .10 Exhaust (EX) .25 - .25 Can anyone tell me whether I'll need to change the Left Front Inlet now or can it wait until the 30k check, as it's about an 8 or 9 gap. If it does need changing now, what shim size do I need to buy?? Thanks Chin
- SK4.SV650.2004.YC2 - D3N15 |
22-12-08, 08:50 AM | #2 |
Re: Valve Clearance Readings
I'd change it - it isn't that difficult and if it's a dab narrow there is the possibility of damage.
The shim needed is calculated dependant on the size of the shim that's in there now.
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 22-12-08 at 08:53 AM. Reason: Missed a bit. |
22-12-08, 08:54 AM | #3 |
Thanks for such a quick response Mr Squid.
I know that your advice is Gospel, so I'll get it changed as soon as. I just wanted reassurance that it needed changing now. Thanks again. Chin
Thread Tools | |
Valve clearance checking. | Mark_h | SV Talk, Tuning & Tweaking | 6 | 22-12-08 08:31 AM |
Valve Clearance Tight | stnd | SV Talk, Tuning & Tweaking | 2 | 02-09-08 10:52 PM |
A question of valve clearance... | BillyC | SV Talk, Tuning & Tweaking | 11 | 23-11-05 12:36 AM |
15k service - valve clearance | The Mass | SV Talk, Tuning & Tweaking | 21 | 18-08-05 09:41 AM |
Valve Clearance | Craig | SV Talk, Tuning & Tweaking | 3 | 14-02-05 07:34 PM |
