Hi all i've bought some Daytona heated grips and need some help as to which & where i can wire them into the loom etc.
The instructions say orange & black/white in the head lamp feeds but my K2 curvy dont have the said coloured wiring. Any help would be appriciated, my chuffing hands are killing me ![]() Thanks for any info. |
The thick orange wire is up at the ignition switch, not the headlamp. I think you'll find it goes under the tank rather than forwards into the headlight shell if your bike is a naked model. Failing that, you can pick up the fat orange wire under the seat at the fusebox.
Don't bother earthing via the black/white wire, take your earth wire from the grips direct down to a point on the frame or back to the negative post of the battery. |
Cheers Lozzo will have a look after.
Did you get them fitted and are they working OK? I was having problems with mine (see earlier post).
Thread Tools | |
heated grips | zsv650 | Bikes - Talk & Issues | 6 | 08-12-08 11:48 AM |
Heated Grips? | smidge26 | Riding Gear | 41 | 09-11-08 01:06 PM |
Heated grips | skint | Bikes - Talk & Issues | 19 | 06-01-07 10:09 PM |
getting heated grips off -more help please!! | jenni | SV Talk, Tuning & Tweaking | 21 | 07-12-06 05:53 PM |
Heated grips | jimbobule | Idle Banter | 3 | 09-01-70 09:04 AM |
