Just looking for some help/suggestions. Went to take my bike this morning as I have an exam later. Turned the ignition on and all the lights came on as normal, then there was a small click and everything went of. Now when I turn the ignition on, nothing happens, no lights or anything.
Anyone got any suggestions as to what it may be? I'm thinking maybe a fuse or something. Is there a master fuse somewhere? Not had a chance to look yet as I had to rush for the train. Any help would be much appreciated, plan to have a look when I get home tonight. cheers Gavin |
Has not happend to me before but it sounds like a fuse has blown. The fuse's are under the riders seat by the battry if i rember correctly, Dom
oh yes i remember this absolutly **** meself it is the main fuse its located behind the right (rear brake side) plastic infill below the seat there is normally a spare in the green (mine is green) cover for the fuses
old one out new one in total job time 30 seconds hth |
as said check your fuses, sounds like the main fuse like dave said - check that first.
That's great, that's what I was thinking. I thought there'd be a main fuse somewhere. I'll check that when I get home, hopefully thats all it is. Thanks for your help.
What year bike is it?
It's a '99 curvy although it's a 2000 model if that makes any difference. Dunno how it happened but it's GCB so definetly a 2000 model so I'm told.
If it goes again after replacing it it's time to check all your wires to see if any have worn through.
#9 | |
On the right side of the bike behind the saddle shutters (black triangles) is the starter relay, its black with a 'green/yellow' cover I think, in there is a 30 amp fuse. It controls the supply to everything, so if it pops you have a dead bike. Also on the older bikes this 'starter relay' tends to corrode and do odd things to the electrics, so have a look at it and make sure nothing looks like it going green and fuzzy. |
#10 |
cheers, I'll have a look. Dunno if water has maybe got in somewhere as it was very very wet on Wednesday when I was last out. Might just be coincedence though.
Thread Tools | |
My Bike Won't Start :( | arcdef | SV Talk, Tuning & Tweaking | 34 | 01-02-09 08:38 PM |
Help! bike doesn't start | DJ828 | Bikes - Talk & Issues | 10 | 26-03-08 11:12 PM |
bike won't start | magicrat | SV Talk, Tuning & Tweaking | 9 | 16-02-08 02:31 PM |
My Bike Won't Start! | Yellow | Bikes - Talk & Issues | 4 | 01-09-07 08:31 PM |
Clocks start spinning and bike wont start?! | lockery | SV Talk, Tuning & Tweaking | 4 | 13-04-06 07:32 AM |
