Old 13-09-09, 01:15 PM   #1
DaveW_42
DaveW_42's Avatar
Default front fork bush question
Hi all,
Been swapping over the internals from my bent race forks with some donor forks. Managed to open 3 out of 4 of the forks - one bottom bolt still refuses to do anything other than just spin - even with the broom handle method.
I've got to the stage of replacing oil seals on the first fork but I can't seem to get it in far enough.
Does the top bush push all the way in so it's flush with the recess inside the fork? ie. inbetween the stanchion and the internal bottom part of the fork. If it does, how on earth do you drive it in? I presume the washer then sits flush on top and the oil seal sits on top of that.
I've been at this all weekend and it's starting to really pi$$ me off!
Cheers,
Dave
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings.
DaveW_42 is offline   Reply With Quote
Old 13-09-09, 03:52 PM   #2
Speedy
Default Re: front fork bush question
Usually fork bushes are situated near the top, then the washer then the seal.
Bush is as near to top as possible to give support to the stanchion as it moves in and out. If it was at the bottom of the slider, you'd have masses of movement between the slider and stanchion.
Hope this is of some help.
Old 13-09-09, 05:37 PM   #3
sam anon
Don't know how to rectify this, you generally crack the bolt first then continue with dissassembling them. Could you put them back together again to allow you to loosen the bolt?
Yep, the upper bush does sit flush with the top of its cavity. I used a hardwood "thing" to tap it in, doing little taps while working around the edge, paying particular attention to where the bush splits.
Old 13-09-09, 06:26 PM   #4
Speedy
Not stripped an SV fork yet, do they not have a slot on the damper rod to hold it while you undo the bottom screw?
Fork seals and bush prices - WT*? sam anon SV Talk, Tuning & Tweaking 5 30-01-09 02:22 PM
Fork seal question. Sideshow#36 SV Talk, Tuning & Tweaking 1 22-02-08 06:12 PM
Fork oil question........ Davies SV Talk, Tuning & Tweaking 8 25-07-06 01:43 PM
fork question lukemillar SV Talk, Tuning & Tweaking 5 01-05-06 07:08 PM
Fork spring question.... Junior SV Talk, Tuning & Tweaking 4 07-01-05 09:20 AM
