30-12-10, 01:08 PM | #1 |
battery/GSXR rear shock query.
I have just fitted a K4 gsxr thou rear shock. Have cut the battery box ect. However, now that the battery is so elevated, i have to apply a fair amount of pressure to get the seat on and bolted in. Is this a problem or is it ok for the seat to be applying pressure on the top of the battery?
Cheers |
30-12-10, 01:10 PM | #2 |
Re: battery/rear shock query
No a good idea me thinks
30-12-10, 01:13 PM | #3 |
30-12-10, 01:20 PM | #4 |
Think the solution is to either cut a section out from under the seat, or to space the battery away from the shock, so it sits in its holder properly.
See what the wisdom of the Org comes up with? Pics would help too
30-12-10, 01:26 PM | #5 |
have you cut down the grey foam block under the seat?
30-12-10, 01:28 PM | #6 |
30-12-10, 01:35 PM | #7 |
30-12-10, 01:57 PM | #8 |
if i recall i had to give a little push when i done mine and i'm sure that the battery was touching the seat as i had also removed the grey block.
30-12-10, 02:25 PM | #9 |
Did the fact that the battery was touching the seat cause any issues to the seat or battery over time?
Am still unsure whether it is an issue or not |
30-12-10, 02:55 PM | #10 |
i had the bike converted for about a year before it got stolen and seen no ill effects. i would keep an eye on the reservoir on the shock touching the battery as this will wear the battery casing.
Thread Tools | |
gsxr 600 rear shock | stamasman | For Sale - Other Bikes and General biking items | 1 | 18-10-10 01:31 PM |
GSXR rear shock for K3 | marcosa | SV Talk, Tuning & Tweaking | 2 | 29-09-10 10:55 PM |
Cutting battery box to fit GSXR shock? | redeye321 | SV Talk, Tuning & Tweaking | 0 | 05-06-10 07:49 PM |
GSXR 750 rear shock | Zubanoid | SV Talk, Tuning & Tweaking | 19 | 02-10-08 08:26 PM |
GSXR Rear Shock....! | bobit69 | SV Talk, Tuning & Tweaking | 18 | 06-03-06 12:31 AM |
