24-09-11, 12:35 PM | #1 |
Misfire - K5.
Hi Motorcycle lovers
Need some help. A couple of weeks ago my k5 SV650s developed a fault. At riding temp around 80degrees it misfires I have just had it on a dyno for a diagnostics check and it has come up with no fault. The thought is it could be a Crank Position Sensor as the place have had a motorcycle (not an sv) in with the same problem and it turned out to be the C.P.S. I have checked the ht leads, spark plugs, vacuum hoses and all the connections. Has any one had the same problem with their SV. |
24-09-11, 12:44 PM | #2 |
Re: Misfire while riding
Mine did this and surged as well, replaced plugs with Iridiums which solved it, not to say it will on yours though.
24-09-11, 12:50 PM | #3 |
I have changed the plugs however not for iridiums, was thinking of changing to iridiums so I shall give them ago.
Cheers for the suggestion Stormingjoe |
26-09-11, 11:35 AM | #4 |
Re: Misfire - K5.
Both my Sv's did this at some point. I fiddled around with the air box and mountings to the carbs and throttle bodies which seemed to fix it for me?
Not sure if this will help |
26-09-11, 05:02 PM | #5 |
Re: Misfire - K5.
did you gap the new plugs to the correct figure?
05-10-11, 05:19 PM | #6 |
Re: Misfire - K5.
Thanks for all the suggestions and advice, I have sorted the problem.
It was the throttle position sensor. |
Thread Tools | |
Misfire | SvJoy | SV Talk, Tuning & Tweaking | 1 | 07-05-11 11:42 AM |
Misfire? | nickodemon | SV Talk, Tuning & Tweaking | 1 | 29-12-09 07:03 PM |
Misfire? | Phaelok | Bikes - Talk & Issues | 6 | 01-11-08 08:04 PM |
low rev misfire?? | ricky | SV Talk, Tuning & Tweaking | 6 | 25-09-08 06:19 PM |
MISFIRE | DAX | SV Talk, Tuning & Tweaking | 5 | 18-05-06 10:19 AM |
